Gents, did you had any success?
Again I don't have tech2 yet it comes in 3-5 days
but surely pecky can fill the exact detail
As I understand go to update your two line display
when the tech2 has received the bin from the PC
Remove the PCMCIA card and swap the bin with the 3line bin
Continue updating
This will flash the 3line to the two line
Hopefully somebody can be more dice improve on the hot swap as I don't have a tech two to test yet! Once I have it and tested I'll post results
If you have a copy tech2 card with a 3 line CID dump, you can send me I'll test it.
You just don't read you need to edit your 2line cid sps request on the tech2 card
If I understand you correctly, at SPS request, in the card of tech2 one should find the bin file to be edited? Do you know more details, where exactly is this file stored, what needs to be changed and so on?
Not find the bin but edit the request so it requests that GTIS uploads ce83 to the card
Then sps the screen
Hi Guys,
sorry to but in but have a quick question and you all seem to know your stuff
just put a cid in mine, programmed it in ok all working apart from the board computer, can i change the code index using opcom? or does it have to be a tech2 job?
as i can't seem to get up any options in the code index on the cid
thanks
Board computer is in variant aswell
not sure what you mean ?
mines got the id BN
and is currently showing on opcom of having a code index of 008
which means without board computer can i change it to 009 with opcom
sorry if I'm being thick lol
Change it to 9 and if it's not there you need to activate it in vaerient
