It is aftermarket, or is a New roof aerial and wiring, which will cost £80-100.
Fakra antenna can be fitted out of sight and does the same thing for £8
ok cheers pecky , il have a brain storm im also curious can i just fit the cd70 head unit , cid , rgb and aerial then get it tech'd in ? are there any codes from any part that i need to write down ?
tim
It all depends if they are divorced or not. If they are coded differently, then no you can't fit them. If either the display or CID is divorced and you know the code you can fit, if they are both divorced you can fit.
If you don't know any of the codes, you can't fit.
i bought this one
http://www.ebay.co.uk/itm/300707136616
so is it possible for the parts to be paired and fitted without the codes ?
tim
cheers for the info thus far mate , couldnt have done it without ya dont suppose you know the part numbers for the vx aerial and rgb cable .
tim
You are mental if you are going the VX aerial route, the wire is around £30, the aerial base £40 and the mast around £20, when an £8 part does the same thing.
http://www.diagnostics.org.uk/help/s...ull=1#post2415 for the aerials
http://www.vauxhallworldparts.com/va...umber=13185491 for RGB lead
ta mate for the feedback youve sort of opened my eye's any links for the fakra i had a look on ebay and there was quite a few different parts . Oh and cheers for the links mate .
tim
http://www.ebay.co.uk/itm/270932799774 is where I have had a few from and work fine with the CD70
