Hi
I know in the display, code index is 5 and 2, I do not remember what I have now and what should be in the IPC
You changed code index in ipc?
If you changed code index in ipc and not in cid than change it back to what it was before
Hi
Ok than as far as i understand you did as fallowing
Programmed display for code index 005 02?
Than you got wrong bc readings?
Than you changed ipc code index to get right bc readings?
Is that how you did it?
Hi on display now code index is 5 and 2 and shows perfect range, when I bought the CID tried all the index in the display and I could not set correctly then I changed the IPC index, and now is the perfect.
I did not have time to check this IPC index in the evening because back late but surely over the weekend and I let you know thanks
Hi
domtorredo thanks a lot, I changed IPC index code from 009 to 003 and it working now, I never thought that the speedo has something to do with the wiper.
Thanks to all for help
Glad you sorted it, hows you bc showing now?
Hi
shows the same as before but I have not tested properly
Thanks again
