I have just retrofitted the fog lights and change the light switch etc.
Cant get the fogs to work, on my tech2 it says fog light switch open circuit etc
Front what I can work out there should be a cable from that switch to the ipc for the front fog lights on pin 28 on the ipc
does anyone know what pin it should be on the switch? I have pins 1, 3 and 8 with no wires in?
Thanks guys
I may just try each pin tomorrow when I get chance just need to confirm this is wired directly to the ipc?
