Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 37
  1. #11
    1,367
    omg, thats very very weird, pulls a different number each time lol
    • #12
      1,367
      only on that bin though, others are fine
    • #13
      1,367
      the bin file looks slightly different, no Vin No. or such and doesnt pull it from 8a... looks like its getting data from last two bytes of 7a, 7b maybe?
    • #14
      Member crystyxcw's Avatar
      May 2013
      Bucharest
      31
      Vectra C
      I will try to programm it tomorrow, and update with the result.
    • #15
      1,367
      Quote Originally Posted by sarah1331 View Post
      What does it say where my locations say
      the decoder should pull it from where the code is. But whatever the decoder is using as a 'tell' to work out which location it should use is getting confused by the .bin file.
      I suspect the .bin file is either not fully correct or been played with..
    • #16
      Member sarah1331's Avatar
      Dec 2013
      Rotherham
      442
      Vectra c
      The code can be in either location I have had 5or 6 insignia IPC and all have been in one of the two 50/50 for witch
    • #17
      May 2013
      Bucharest
      31
      Vectra C
      Do you need me to retry reading the eprom? and upload it again?
      I have tried to program the ipc with my vin code with MDI and also with op-com so that should be the problem not showing the vin.
    • #18
      1,367
      yep, but the decoder isnt looking in the right place for it...
      If theres a choice of two locations then you have to look for a difference between the two bin files which is repeatable every time.. You then set the program to look for the difference and determine which location to use for the code... If the bin file is bad or been played with then the 'lookup' would be thrown off...
    • #19
      1,367
      Quote Originally Posted by crystyxcw View Post
      If you can please. Are you clipping it or removing it?
    • #20
      Dec 2013
      Rotherham
      442
      Vectra c
      I see I don't have your program so didn't know that
  1. wanted vectra ipc eprom dump
    By Alan Ansell in forum Vectra
    Last Post: 12th August 2019, 07:57 AM
  2. Meriva B uplevel IPC dump.. anyone got
    By gazz292 in forum Decoding
    Last Post: 2nd March 2018, 08:27 PM
security code from dump insignia
insignia ipc eeprom
insignia dump eeprom
insignia code new tpms sensor
insignia IPC reprogramming
insignia programming Ipc
insignia IPC dump
2012 insignia uplevel ipc
