Yes its vxr ecu
Can some confirm these are vxr ecus please there are out the back of a mates garage and there is also vxr clocks and uec, barrel key ect.
Thanks jon.
Yes its vxr ecu
Maybe you will sell clocks?
Unfortunately not mate I need to identify the ecu that matches the clock and return them to there owner. Which evrr ecu is left will be going on my astra h sri turbo.
Ok no problem
just been given these, off a mate again he's having a clear out and no use to him so iv claimed them.
need to some help decoding them as I plan on fitting one and selling other.
do I have to pull the plastic back off or can I connect to the pins on them and read she chip.
astra/zafira ones I have had to strip them down and pull the chip... be careful about the ribbon display/bezel, you can release the bezel to avoid strain/lift on the ribbon.. You get the bin file and of course we will help..
so heat it up and pull the back off it read chip, is the ribbon to the plugs mate
