No probs than in your case fuse 32 & 20 and check relay
Thank you, my car is a 1.4 petrol with a rec in the boot. Will do that. Thank you
Vauxhall wants to look at it but it's expansive. They think there is an electrical problem somewhere. My car has ecc
Ok will check info for ecc
Check fuse 4 in rec
Thank you. Will do that. Worst case scenario, if that didn't work what should I do?
Sorry whats a relay?
If you look in pic posted before relays are square boxes yellow black brown grey they wont be easy to test but if you want can explai or check on net there is few tips how to do that
In worst case i would double check if system still has pressure in it
Here is tip quite easy how to test them http://www.youtube.com/watch?v=1V-q5qlpTWA&sns=em
