pecky can you tell me the code please so I can devorce and remarry to my car
thank you
https://mega.co.nz/#!zMxGWZqJ!ZLCTBU...SXHBAthKUCXgmY
thank you
2608
Regards Mark
pecky I have purchased
astra h sri clocks there not divorced can I program with opcom knowing the code or must they be reset
I also have some vxr clocks the same not divorced I am torn between vxr needle sweep (no glow plug teltale) and the sri ones , I need to swap as my clocks don't show cruse control that I have installed
Was the cruise control programmed with OPCom? If so, then that may be the reason why the light doesn't show. I had this on my Zafira originally, as soon as I got Vauxcom, reprogrammed it and hey presto ... working.pecky I have purchased
Vauxcom is opcom
My clocks don't have the actual simble or the led for it
Yes, but most people are using an out of date chinese clone version that doesn't fully support cars.
Ah, OK ... I know a lot of people have problems getting the CC symbol to light up, as did I until I got the up to date Vauxcom.
thought of adding the led to the clocks where it doesnt light up plus the resistor it will probably need. I've looked into this on a set of vectra clocks that didnt have the ids+ led, followed the traces back to the chip and the chip is outputting 11v when commanded by 'telltale' test on tech2.. Maybe the same for you would work?
Put the clocks in reset with the code, then program with your cars code. If it's a clone opcom I wouldn't like to comment on it ability to program the ipc, as I use tech 2 or the mdi but the genuine opcom/vauxcom should be able to.pecky I have purchased
If you use the vxr set the rev counter will also be wrong.
I have a spare set of diesel clocks with the needle sweep programmed.
Regards Mark
genuine opcom cannot do it
I put clocks in and use clock or my code it fails
if I reset my clocks first then instal new ones it fails on the code
can anyone devorce by dump??
can tech2 even devorce or is it like opcom must it be in original car
