Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Member sarah1331's Avatar
    Dec 2013
    Rotherham
    442
    Vectra c
    clocks decode please
    pecky can you tell me the code please so I can devorce and remarry to my car
    thank you
    https://mega.co.nz/#!zMxGWZqJ!ZLCTBU...SXHBAthKUCXgmY
      Member Mark I's Avatar
      Nov 2012
      Brackley, Northants
      86
      Astra H sportive van 1.7cdti
      2608
      Regards Mark
      Dec 2013
      Rotherham
      442
      Vectra c
      thanks buddy will try
      Dec 2013
      Rotherham
      442
      Vectra c
      pecky I have purchased
      astra h sri clocks there not divorced can I program with opcom knowing the code or must they be reset
      I also have some vxr clocks the same not divorced I am torn between vxr needle sweep (no glow plug teltale) and the sri ones , I need to swap as my clocks don't show cruse control that I have installed
      Member AndyM's Avatar
      Sep 2011
      Berkshire
      40
      Zafira VXR
      Quote Originally Posted by sarah1331 View Post
      Was the cruise control programmed with OPCom? If so, then that may be the reason why the light doesn't show. I had this on my Zafira originally, as soon as I got Vauxcom, reprogrammed it and hey presto ... working.
      Dec 2013
      Rotherham
      442
      Vectra c
      Vauxcom is opcom
      My clocks don't have the actual simble or the led for it
      Sep 2011
      Berkshire
      40
      Zafira VXR
      Vauxcom is opcom
      Yes, but most people are using an out of date chinese clone version that doesn't fully support cars.
      Ah, OK ... I know a lot of people have problems getting the CC symbol to light up, as did I until I got the up to date Vauxcom.
      thought of adding the led to the clocks where it doesnt light up plus the resistor it will probably need. I've looked into this on a set of vectra clocks that didnt have the ids+ led, followed the traces back to the chip and the chip is outputting 11v when commanded by 'telltale' test on tech2.. Maybe the same for you would work?
    • #9
      Nov 2012
      Brackley, Northants
      86
      Put the clocks in reset with the code, then program with your cars code. If it's a clone opcom I wouldn't like to comment on it ability to program the ipc, as I use tech 2 or the mdi but the genuine opcom/vauxcom should be able to.
      If you use the vxr set the rev counter will also be wrong.
      I have a spare set of diesel clocks with the needle sweep programmed.
      Regards Mark
    • #10
      Dec 2013
      Rotherham
      442
      Vectra c
      genuine opcom cannot do it
      I put clocks in and use clock or my code it fails
      if I reset my clocks first then instal new ones it fails on the code
      can anyone devorce by dump??
      can tech2 even devorce or is it like opcom must it be in original car
  1. VXR Clocks
    By Gav in forum Astra
    Last Post: 16th January 2015, 09:11 PM
  2. Clocks
    By jace1969 in forum Corsa
    Last Post: 8th July 2014, 11:47 AM
  3. Mk5 van clocks/Vxr clocks
    By Mktn in forum Astra
    Last Post: 26th January 2013, 07:07 PM
