Soldering iron
If your uk send me your screen and cd70 I'll sort them out and divorce or marry whatever you like
Hi, How do I go about removing chip from CD 70 as it is glued to pcb? Cheers Andrew
Soldering iron
I think it is leg 1 I have broken trying to get chip off, is leg 1 needed? Cheers Andrew
I agree. LOL. What should I do now?
If I posted my CID screen and CD 70 pcb would you be able to sort it for me and I will give your my security code for my car? If so how much will it cost? Cheers Andrew
I have no problem resoldering the chips if that helps maybe by you just doing chip for CID and CD 70?
If you can remove the chips without damaging the pcb then do so but your breaking legs isn't a good start flood all 8 legs with solder and remove chip at once
Thanks but on CD 70 pcb the chip is glued to the pcb under chip. Can you point me in right direction for virgin or unpaired eeprom dumps please? Cheers Andrew
If you flood with solder the heat will let the "glue" let it go
