DDS & ESP Compatible - Required for TPMS
93186185 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT AM) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93191515)
93182328 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HC) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93186185)
93182326 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GY) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93182328)
93180955 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GT) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (FOR DEFLATION DETECTION SYSTEM) (NLS.- USE 93182326 OR 93182448 AS REQUIRED)
This is the latest one that is DDS compatible
93191515 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT BN) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT)
HILL START ASSIST & ESP Compatible
93190007 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (FOR ELECTRONIC STABILITY PROGRAM) (FOR HILL-START ASSISTANT) (IDENT BP)
93186183 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT AK) (FOR ELECTRONIC STABILITY PROGRAM) (FOR HILL-START ASSISTANT) (NLS.- USE 93190007)
93183027 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HD) (FOR ELECTRONIC STABILITY PROGRAM) (FOR HILL-START ASSISTANT) (NLS.- USE 93186183)
93182450 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GZ) (FOR ELECTRONIC STABILITY PROGRAM) (FOR HILL-START ASSISTANT) (NLS.- USE 93183027)
93178596 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GQ) (FOR ELECTRONIC STABILITY PROGRAM) (FOR HILL-START ASSISTANT) (NLS.- USE 93182450)
ESP Compatible Only
(93186182) UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT AJ) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (NLS.- USE 93191515)
(93183038) UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HK) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (NLS.- USE 93186182)
(93182448) UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HJ) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (NLS.- USE 93183038)
(93186184) UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT AL) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93191515)
(93182332) UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HB) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93186184)
(93182334) UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GX) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93182332)
(93178594) UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GP) (FOR ELECTRONIC STABILITY PROGRAM) (EXCEPT HILL-START ASSISTANT) (EXCEPT DEFLATION DETECTION SYSTEM) (NLS.- USE 93182334 OR 93182448 AS REQUIRED)
NOT Electronic Stability Programme Compatible
93191453 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (EXCEPT ELECTRONIC STABILITY PROGRAM) (IDENT BK)
93186371 UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HA) (EXCEPT ELECTRONIC STABILITY PROGRAM)
(93183032) UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT HA) (EXCEPT ELECTRONIC STABILITY PROGRAM) (NLS.- USE 93186371)
(93182330) UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GW) (EXCEPT ELECTRONIC STABILITY PROGRAM) (NLS.- USE 93183032)
(93174919) UNIT, HYDRAULIC, ABS, WITH CONTROL UNIT (IDENT GN) (EXCEPT ELECTRONIC STABILITY PROGRAM) (NLS.- USE 93182330)
