Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 36
  1. #21
    Member Smart74's Avatar
    Jun 2014
    Darlington,County Durham
    129
    Astra mk5 sri 1.9cdti estate
    Or could ya just change the navi board if had another one if I was that fussed if not mite just leave as it is or put my cd30 mp3 bac in and use that with cid screen instead if that was the easiest option?
    Sorry this part of thread is in very c cd70 instead of astra cd70 thread.
    • #22
      1,367
      you would need to get another navi board from a good radio or a scrap one, sort of defeats the point... then there are two types of navi board, then you would need to desolder it off of the motherboard
      as for if its worth it or not only you can decide...
    • #23
      Jun 2014
      129
      It was just bit strange that was all one min working ok then all ov sudden it just stopped after I tryed ejecting disc to see if ok so the option pecky mentioned do ya strip down cd70 and flash eeprom with another eeprom bin file just thought ide ask?
    • #24
      1,367
      yes, put on a different bin file with same ident, you'd need to recode your radio to the screen, but imo doubt it will cure it....
    • #25
      Jun 2014
      129
      If I did go down that root first how would i get the different bin file and then would I have to decode again bac to my code after recoding screen If that makes sense?
    • #26
      1,367
      you would ask if anyone has one, you would unpair your existing radio/screen. flash the new bin file to the radio then pair them both back up again with your code
    • #27
      Jun 2014
      129
      So I'm guessing the new bin file if someone had one it won't have an existing security code it would be in reset mode?
    • #28
      1,367
      all depends what they have, and if both are yours are tech2 then it wont make any difference as you would just pair the screen up the radio using the radios dumps pre (new dumps code) existing code
    • #29
      Jun 2014
      129
      Ok think know what ya mean as in regards what ya said before aswell if navi board was changed over would it be straight forward or do you av to change eeprom over too cause never stripped or looked inside ov cd70?
    • #30
      1,367
      navi board is just a daughterboard so no coding
  1. Cd70 navi problem?
    By TRIGGAR in forum Infotainment - ICE - In Car Entertainment
    Last Post: 27th March 2016, 10:03 PM
  2. Please help cd70 navi gps problem
    By lfcmassive in forum Infotainment - ICE - In Car Entertainment
    Last Post: 12th October 2015, 02:14 PM
  3. Cd70 navi problem?
    By 1rado in forum Zafira
    Last Post: 10th October 2013, 09:06 AM
cd70 navi no gps
cd70 navi no navi tab
cd70 rgb cable
corsa c cd 70 navi
cd70 navi not working
cd 70 navi not working
cd 70 navi problem
sat nav not working in vauxhall vectra
vectra cd70 bluetooth
cd70 navi no sat nav tab
cd70 gps not working
cd70navi no arrow
vauxhall vectra cd70 head unit not working
cd70 navi no notifications
does cd70 navi have bluetooth
cd70 navi tuning problem
cd70 navi dab
cd70 navi gps antenna
programming a cd70 navi vauxhall vectra
gps not working in cd70 navi
fitting cd70 navi
signum GPS not working
plug in cd70 gps aerial
signum cd70 bluetooth
why my sat nav not workin on my cd70 signum
