Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
  1. #11
    Member teash's Avatar
    Apr 2014
    bolton
    4
    astra mk5 cdti sri
    I got it sorted out chief but I did it a different way. Basically I dug the rest of the loom out that came with the sensors and noticed the sensor wires ended up going to a multiplug which was the same as the plug on the aftermarket wires that go into the park module. Split them both open and matched the new coloured wire to the old, traced that down to the x41 and one by one matched (oviously) what you was saying about the wires and pin position. The only slight different was the old loom compsred to the new was earth and live are different colous. Added the fuse from the from the new loom and basically job done. So now at least theres a definate way ofdoing this especially as you cant buy the loom that comes with part of the kit. Many thanks for your help buddy
    • #12
      Member Frostic's Avatar
      Jul 2013
      Luton
      27
      Astra MK5 Elite 1.6
      Nice one glad you got it sorted :-)
    • #13
      Member pgeddes79's Avatar
      Jan 2018
      Scotland
      9
      Astra H 1.7 CDTI SRI
      I know this is a 3 1/2 year old thread but hope someone can help. I have the same problem with the different connectors for the Park Pilot and having a look at the pin outs on post 3, I also can't see the pin numbers on the X41. Does anyone have this so I can join the wires together correctly? Thanks.
    • #14
      Member Lansa's Avatar
      Feb 2018
      Antwerpen
      12
      Astra J 1.7CDTi 96kw, Sport tourer
      here you go.
      GREY -> BLACK WHITE
      BLUE -> BROWN WHITE
      PURPLE -> YELLOW VIOLET
      YELLOW -> YELLOW WHITE
      GREEN -> YELLOW RED
      ORANGE -> YELLOW
      important little note for estates:
      you'll need this bracket to mount the pdc module
      -GM 13125510
    • #15
      Feb 2018
      Antwerpen
      12
      Park pilot code indexes to use:
      station wagon With push button
      • Automatic 003
      • manual 004
      station wagon Without buttons
      • Automatic 007 or 019
      • manual 008 or 020
      4-door With push button
      • Automatic 001
      • manual 002
      4-door Without buttons
      • Automatic 005 or 017
      • manual 006 or 018
      2-door With push button
      • Automatic 009
      • manual 010
      2-door Without buttons
      • Automatic 011 or 021
      • manual 012 or 022
      Convertible With push button
      • Automatic 023
      • manual 024
      Convertible Without buttons
      • Automatic 025
      • manual 026
      notchback With push button
      • Automatic 027
      • manual 028
      notchback Without buttons
      • Automatic 029
      • manual 030
    • #16
      Jan 2018
      Scotland
      9
      Thanks for the reply. Got the wiring sorted out eventually. Haven't fitted it yet, hopefully soon. Big thanks for the code indexes, didn't know about that part. I think the park pilot ecu holder is needed for all cars?
      What is Notchback? Mine is a 3 door Astra H.
      Again, thanks for the reply.
      Quote Originally Posted by Lansa View Post
      • Automatic 003
      • manual 004
      • manual 008 or 020
      • Automatic 001
      • manual 002
      • manual 006 or 018
      • Automatic 009
      • manual 010
      • manual 012 or 022
      • Automatic 023
      • manual 024
      • Automatic 025
      • manual 026
      • Automatic 027
      • manual 028
      • Automatic 029
      • manual 030
    • #17
      Feb 2018
      Antwerpen
      12
      Notchbacks are the sedans and cabrios
      I believe the bracket is only required on estates, sedans and cabrio's
    • #18
      Jan 2018
      Scotland
      9
      Did you use a 29mm bit for drilling the holes in the bumper fro the sensors?
    • #19
      Feb 2018
      Antwerpen
      12
      Sorry for the late reply!
      I bought a used bumped with the sensors already in them, and then retrofitted them. Gives the best look compared to retrofitting the sensors themselves.
    • #20
      Jan 2018
      Scotland
      9
      For anyone reading this, it's not a 29mm hole for the sensors unless you have the full aftremarket kit! The instructions for the kit say it's 29mm but it's too big. It was a 25mm hole needed. I just need to tidy up the holes a bit. Quick question though - the PDF guide says that fuse 15 has to be used. Unfortunately, there are no metal contacts there so can't be used. The Haynes manual says that parking sensors use fuse 13. There was already a 5 amp fuse in there already so removed that and used the piggy back fuse holder with the two 5 amp fuses. Will this be an ignition live fuse? Thanks.
  1. Astra H Park Pilot retrofit
    By vasilik in forum Astra
    Last Post: 7th April 2021, 07:25 PM
  2. park pilot astra h can issue
    By arshad in forum Astra
    Last Post: 11th December 2014, 07:51 PM
  3. Replies: 3
    Last Post: 15th July 2012, 07:07 AM
astra h park pilot retrofit
astra h park pilot problem
astra h park pilot
93160432 PDF
