Yes it can be done but tricky.... The idea is to use your existing setup to help.. ie.. unpair both of your units and then for example recode with the code for the new screen.... then remove existing screen fit new screen and then you should be able to unpair both of them... then you can refit your existing screen and then unpair that as well.. and then repeat the same process for the radio. It depends on what you already have in the car already as not all radios work with all screen and visa versa.. Pecky will hopefully be along for some better input on the subject
