Pin assignment
PinColorWire sizeOptionFunction
1Red2.5.Battery Positive Voltage
2Brown0.5/2.5 .Ground
3Red0.75Open & StartDoor Lock Control
3Red0.75 Open & Start Rear electronic moduleDoor Lock Control
4White0.75Open & StartDoor Unlock Control
4White0.75 Open & Start Rear electronic moduleDoor Unlock Control
5Black-Green0.75Open & StartAll Door Deadbolt Motor Lock Control
5Black-Green0.75 Open & Start Rear electronic moduleAll Door Deadbolt Motor Lock Control
6Gray0.5Open & StartLeft Rear Door Ajar Switch Signal
6Gray0.5 Open & Start Rear electronic moduleLeft Rear Door Ajar Switch Signal
7Violet-Brown0.5.Power Window Master Switch Left Rear Down Signal
8Violet-Green0.5.Power Window Master Switch Left Rear Up Signal
9White-Blue0.5.Power Window Master Switch Lockout Signal
10Yellow-Brown0.5Open & StartLeft Rear Door Handle Switch Signal
11Blue-White0.75Open & StartLeft Rear Door Unlatch Motor Unlatch Control
12White-Black0.75Open & StartDoor Latch Unlatch Motor Low Reference
13Brown-Black0.5.Power Window Comfort Close Signal
15Brown-Green0.75Hatchback (5 doors) / EstateLeft Rear Speaker Signal (-)
16Green0.75Hatchback (5 doors) / EstateLeft Rear Speaker (+)
