Results 1 to 10 of 11
Hybrid View
    Member phill147's Avatar
    Jan 2014
    chesham
    5
    astra mk5
    astra mk5 1.9 alternator help
    just took alternator of and there is no lable for part no or amp rating not sure if its denso or bosch no marks anyware also are there 2 trigger wires that should go on back of alternator red/blue which is with main wire in loom and a white/blue wire separate as they both have small eye loop connectors
    reg of car vf55 yhd also it has a clutch pulley how do you check if its ok
    does anyone have wiring diagram for this please
    astra 1.9cdti z19dth 130bhp
  2. #2
    By your reg got fallowing vin W0L0AHL486508228X (full vin not showed with reason)
    EPC info says denso, 100AMP, part number: R1530098
    http://www.genuinepartsearch.co.uk/v...0-bd3d682e16a8
    pm your email will send you wiring diagram if needed
    there is 4 wires on alternator
    RED what goes to B+ (positive)
    Blue/Red what goes to F (field duty cycle signal)
    Blue/White what goes to L (turn on signal)
    And Ground
  3. #3
    Jan 2014
    chesham
    5
    astra mk5
    hi cheers for you help your inbox is full but if you could email me diagrams that would be great email:subaru147@talktalk.net
  4. #4
    have sent, hope you will find everything what's needed if not let me know
  5. #5
    Jan 2014
    chesham
    5
    astra mk5
    still unsure on wires don't know if one should be left off alternator has anyone removed one recently and know if they both go on small terminal or just one cheers
  6. #6
    how many wires you have 4 or 5 must be 4 and all connected
  1. Replies: 1
    Last Post: 29th October 2018, 01:28 PM
  2. Astra mk5 1.9 cdti sri alarm starts
    By Bogdan Niculescu in forum Astra
    Last Post: 17th October 2018, 03:38 PM
  3. astra 1.7cdti mk5 alternator charging
    By jerry2294 in forum Astra
    Last Post: 7th January 2014, 04:37 PM
  4. Alternator Help
    By Adz in forum Mechanical
    Last Post: 14th January 2013, 12:54 PM
3 wires alternator opel astra
astra h 1.9 three leads to alternator
modifications opel 1.9 from denso alternator to bosch
bluered wire mk5 astra alternator
how many wires does an alternator have on opel astra
diagram wiring astra h 1.9
astra 1.9cdti alternator field wire
z19dth alternator check
astra h 1.9cdti alternator wire diagram
astra h 1.9cdti wirinh
alternator wire z19dth
opel astra z19dt denso alternator altewiring diagram
opela astra 1.9cdti alternator wiring
what amp alternator for vauxhall astra 1.9 cdti sxi
1.9 zafira 1.9 alternator live wires
astra z19dth wiring diagram
vauxhall zafira alternator wiring diagram
vauxhall cavalier bosch alternator wiring diagram
astra h alternator wiring
