Results 1 to 4 of 4
    Recommended Professional holmes83's Avatar
    Feb 2011
    Genoa
    114
    Corsa D
    DDS System - Corsa D
    is it possible to activate the DDS (http://www.diagnostics.org.uk/help/s...2-TPMS-and-DDS) adding only a button?
      No it isn't normally as the ABS pump has to be compatible. if the car did not have DDS as standard, the pump will probably not be compatible.
      Feb 2011
      Genoa
      114
      Corsa D
      Ok, thanks a lot!
      Member Corsa_D's Avatar
      Aug 2017
      erlensee
      2
      corsa d 1.3 cdti
      Hello. I want to install TPMS on my car. I checked ABS, Esp sensor part number on mycar. and I have TPMS ecu, pressure sensors and GID. But I didn't find TPMS wiring diagram on my TIS version. Because TPMS for Corsa D release 2014 but I don't have new TIS
      TPMS ecu have 4 pins. Do you tell me where these pins wire connect after you look new TIS? XI1/XI2/XI3/XI4 or XI5 which pin?
      Thank you very much
  1. Meriva B, DDS then TPMS.. wiring
    By gazz292 in forum Electrical
    Last Post: 15th April 2018, 05:05 PM
  2. Front camera system
    By armstma1 in forum Insignia
    Last Post: 20th November 2017, 07:45 PM
  3. Front Camera System
    Last Post: 9th September 2014, 09:12 PM
  4. what exaust system for the T8?
    By lejenko in forum Tuning
    Last Post: 19th May 2012, 09:41 AM
corsa d dds
corsa dds
vauxhall corsa vxr dds button
dds vauxhall corsa
https:www.diagnostics.org.ukshowthread.php238-DDS-System-Corsa-D
corsa dds button
tpms vauxhall corsa d
corsa vxr dds
dds button vauxhall corsa
corsa d dds button
corsa d tpms
what is dds corsa
tpms на корса д
DDS corsa button
vauxhall corsa dds button
my corsa does not have a dds button
dds button on corsa
how does dds work in corsa
dds corsa opc
corsa d 2014 dds
opel corsa d 1.3cdti dds
tpms on vauxhall corsa d
what is dds on corsa vxr
what is the dds button in corsa
dds button corsa
