STEERING COLUMN ELECTRONIC MODULE - USED WITH MANUAL TRANSMISSION (-91999999) |
1 |
(13303436) |
(12 32 956) |
MODULE, ELECTRONIC, STEERING COLUMN, RHD (IDENT CN) (EXC.CRUISE CONTROL) (EXCEPT TRANSMISSION CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) (NLS.- NO REPLACEMENT PART) |
(C) |
-91999999 |
1 |
1 |
(13303433) |
(12 32 220) |
MODULE, ELECTRONIC, STEERING COLUMN, RHD (IDENT CR) (FOR CRUISE CONTROL) (FOR TRANSMISSION CONTROL) (FOR STEERING WHEEL RADIO OPERATION) (NLS.- NO REPLACEMENT PART) |
(C) |
-91999999 |
1 |
Note: ONLY ONE OR MORE OF THE ABOVE POSITIVE OPTIONS IS REQUIRED TO BE FITTED TO VEHICLE |
2 |
13243379 |
12 32 320 |
-MODULE, ELECTRONIC, STEERING COLUMN (IDENT AQ) (EXC.CRUISE CONTROL) (EXCEPT TRANSMISSION CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) |
(C) |
-91999999 |
1 |
2 |
13243373 |
12 32 318 |
-MODULE, ELECTRONIC, STEERING COLUMN (IDENT AH) (FOR CRUISE CONTROL) (FOR TRANSMISSION CONTROL) (FOR STEERING WHEEL RADIO OPERATION) |
(C) |
-91999999 |
1 |
3 |
12771368 |
51 99 384 |
--SENSOR, STEERING ANGLE |
(C) |
-91999999 |
1 |
4 |
25881206 |
51 99 687 |
--MODULE, ELECTRONIC, STEERING COLUMN (EXC.CRUISE CONTROL) (EXCEPT TRANSMISSION CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) |
(C) |
-A1999999 |
1 |
4 |
25947775 |
51 99 688 |
--MODULE, ELECTRONIC, STEERING COLUMN (FOR CRUISE CONTROL) (FOR TRANSMISSION CONTROL) (FOR STEERING WHEEL RADIO OPERATION) |
(C) |
-A1999999 |
1 |
5 |
25881204 |
12 35 924 |
--BRACKET, TURN-SIGNAL UNIT (EXCEPT STEERING WHEEL HEATING) |
(C) |
-91999999 |
1 |
5 |
25881204 |
12 35 924 |
--BRACKET, TURN-SIGNAL UNIT (FOR STEERING WHEEL HEATING) |
(C) |
-91999999 |
1 |
6 |
25881205 |
12 35 925 |
--HOUSING, IGNITION SWITCH (EXC.CRUISE CONTROL) (EXCEPT TRANSMISSION CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) |
(C) |
-91999999 |
1 |
7 |
25799292 |
12 35 923 |
--HOUSING, IGNITION SWITCH (FOR CRUISE CONTROL) (FOR TRANSMISSION CONTROL) (FOR STEERING WHEEL RADIO OPERATION) |
(C) |
-91999999 |
1 |
8 |
(25799293) |
(9 14 395) |
--SWITCH, IGNITION (NLS.- USE 20912838) |
(C) |
-91999999 |
1 |
9 |
(13502301) |
(12 32 304) |
--CONTROL UNIT, IMMOBILIZER (NLS.- USE 13504286) |
(C) |
-91999999 |
1 |
10 |
(11610440) |
(12 35 922) |
--SCREW, SHEAR, M8, SWITCH HOUSING (NLS.- USE 22745845) |
(C) |
-91999999 |
1 |
11 |
11569833 |
12 35 042 |
--SCREW, M3 X 12, STEERING COLUMN ELECTRONIC MODULE |
(C) |
-91999999 |
4 |
12 |
11569832 |
12 35 041 |
--SCREW, M4 X 8, HOUSING, IGNITION SWITCH |
(C) |
-91999999 |
2 |
13 |
11569832 |
12 35 041 |
--SCREW, M4 X 8, IGNITION SWITCH |
(C) |
-91999999 |
2 |
14 |
11570587 |
12 34 100 |
--SCREW, IMMOBILIZER |
(C) |
-91999999 |
2 |
15 |
13500549 |
62 38 872 |
-COVER, THATCHEM CAGE |
(C) |
-91999999 |
1 |
16 |
11570769 |
12 38 837 |
-SCREW, COVER |
(C) |
-B1999999 |
3 |
STEERING COLUMN ELECTRONIC MODULE - USED WITH AUTOMATIC TRANSMISSION (-91999999) |
1 |
(13303434) |
(12 32 954) |
MODULE, ELECTRONIC, STEERING COLUMN, RHD (IDENT CQ) (EXC.CRUISE CONTROL) (EXCEPT TRANSMISSION CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) (NLS.- NO REPLACEMENT PART) |
(C) |
-91999999 |
1 |
1 |
(13303435) |
(12 32 955) |
MODULE, ELECTRONIC, STEERING COLUMN, RHD (IDENT CP) (FOR CRUISE CONTROL) (FOR TRANSMISSION CONTROL) (FOR STEERING WHEEL RADIO OPERATION) (NLS.- NO REPLACEMENT PART) |
(C) |
-91999999 |
1 |
2 |
13243382 |
12 32 321 |
-MODULE, ELECTRONIC, STEERING COLUMN (IDENT AT) (EXC.CRUISE CONTROL) (EXCEPT TRANSMISSION CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) |
(C) |
-91999999 |
1 |
2 |
13243376 |
12 32 319 |
-MODULE, ELECTRONIC, STEERING COLUMN (IDENT AM) (FOR CRUISE CONTROL) (FOR TRANSMISSION CONTROL) (FOR STEERING WHEEL RADIO OPERATION) |
(C) |
-91999999 |
1 |
3 |
12771368 |
51 99 384 |
(C) |
-91999999 |
1 |
4 |
25881206 |
51 99 687 |
(C) |
-A1999999 |
1 |
4 |
25947775 |
51 99 688 |
(C) |
-A1999999 |
1 |
5 |
25881204 |
12 35 924 |
(C) |
-91999999 |
1 |
5 |
25881204 |
12 35 924 |
(C) |
-91999999 |
1 |
6 |
25881205 |
12 35 925 |
--HOUSING, IGNITION SWITCH |
(C) |
-91999999 |
1 |
8 |
(25799293) |
(9 14 395) |
(C) |
-91999999 |
1 |
9 |
(13502301) |
(12 32 304) |
(C) |
-91999999 |
1 |
10 |
(11610440) |
(12 35 922) |
(C) |
-91999999 |
1 |
11 |
11569833 |
12 35 042 |
(C) |
-91999999 |
4 |
12 |
11569832 |
12 35 041 |
(C) |
-91999999 |
2 |
13 |
11569832 |
12 35 041 |
(C) |
-91999999 |
2 |
14 |
11570587 |
12 34 100 |
(C) |
-91999999 |
2 |
15 |
13500549 |
62 38 872 |
(C) |
-91999999 |
1 |
16 |
11570769 |
12 38 837 |
-SCREW, COVER |
(C) |
-91999999 |
3 |
STEERING COLUMN ELECTRONIC MODULE - USED WITH MANUAL TRANSMISSION (A1000001-) |
1 |
13326414 |
12 32 235 |
MODULE, ELECTRONIC, STEERING COLUMN (IDENT DA) (FOR THEFT DETERRENT SYSTEM) (EXC.CRUISE CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) |
(C) A1000001- |
1 |
1 |
(13326411) |
(12 32 232) |
MODULE, ELECTRONIC, STEERING COLUMN (IDENT DD) (FOR THEFT DETERRENT SYSTEM) (FOR CRUISE CONTROL) (FOR STEERING WHEEL RADIO OPERATION) (NLS.- USE COMPONENTS) |
(C) A1000001- |
1 |
2 |
20909329 |
12 32 440 |
-MODULE, ELECTRONIC, STEERING COLUMN (EXC.CRUISE CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) |
(C) A1126455- |
A1999999 |
1 |
2 |
20964878 |
12 32 448 |
(C) B1000001- |
1 |
2 |
20909327 |
12 32 438 |
-MODULE, ELECTRONIC, STEERING COLUMN (FOR CRUISE CONTROL) (FOR STEERING WHEEL RADIO OPERATION) |
(C) A1091049- |
1 |
3 |
25849366 |
1 99 143 |
(C) A1000001- |
1 |
4 |
25881206 |
51 99 687 |
--MODULE, ELECTRONIC, STEERING COLUMN (EXC.CRUISE CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) |
(C) |
-A1999999 |
1 |
4 |
20817715 |
1 99 332 |
--MODULE, ELECTRONIC, STEERING COLUMN (EXC.CRUISE CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) (EXCEPT STEERING WHEEL HEATING) |
(C) B1000001- |
C1999999 |
1 |
4 |
22902363 |
1 99 415 |
(C) D1000001- |
1 |
N |
4 |
25947775 |
51 99 688 |
--MODULE, ELECTRONIC, STEERING COLUMN (FOR CRUISE CONTROL) (FOR STEERING WHEEL RADIO OPERATION) |
(C) |
-A1999999 |
1 |
4 |
20817721 |
1 99 335 |
--MODULE, ELECTRONIC, STEERING COLUMN (FOR CRUISE CONTROL) (FOR STEERING WHEEL RADIO OPERATION) (EXCEPT STEERING WHEEL HEATING) |
(C) B1000001- |
C1999999 |
1 |
4 |
22899138 |
1 99 414 |
(C) D1000001- |
1 |
4 |
20817722 |
1 99 361 |
--MODULE, ELECTRONIC, STEERING COLUMN (FOR STEERING WHEEL HEATING) |
(C) B1000001- |
C1999999 |
1 |
4 |
22926401 |
1 99 416 |
(C) D1000001- |
1 |
N |
5 |
25881204 |
12 35 924 |
(C) A1000001- |
1 |
5 |
25881204 |
12 35 924 |
(C) A1000001- |
1 |
7 |
25799292 |
12 35 923 |
--HOUSING, IGNITION SWITCH (FOR STEERING WHEEL HEATING) |
(C) A1000001- |
1 |
7 |
22807512 |
12 35 092 |
--HOUSING, IGNITION SWITCH (EXCEPT STEERING WHEEL HEATING) |
(C) A1000001- |
1 |
8 |
(25799293) |
(9 14 395) |
(C) A1000001- |
1 |
9 |
13504286 |
12 47 157 |
--CONTROL UNIT, IMMOBILIZER |
(C) B1000001- |
1 |
10 |
(11610440) |
(12 35 922) |
(C) A1000001- |
1 |
11 |
11569833 |
12 35 042 |
(C) A1000001- |
4 |
12 |
11569832 |
12 35 041 |
(C) A1000001- |
2 |
13 |
11569832 |
12 35 041 |
(C) A1000001- |
2 |
14 |
11570587 |
12 34 100 |
(C) A1000001- |
2 |
15 |
13326419 |
12 38 728 |
(C) A1000001- |
1 |
16 |
11570769 |
12 38 837 |
-SCREW, COVER |
(C) A1000001- |
3 |
STEERING COLUMN ELECTRONIC MODULE - USED WITH AUTOMATIC TRANSMISSION (A1000001-) |
1 |
(13326412) |
(12 32 233) |
MODULE, ELECTRONIC, STEERING COLUMN (IDENT DC) (FOR THEFT DETERRENT SYSTEM) (EXC.CRUISE CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) (NLS.- USE 20909324) |
(C) A1000001- |
1 |
1 |
(13326413) |
(12 32 234) |
MODULE, ELECTRONIC, STEERING COLUMN (IDENT DB) (FOR THEFT DETERRENT SYSTEM) (FOR CRUISE CONTROL) (FOR STEERING WHEEL RADIO OPERATION) (NLS.- USE 20909325) |
(C) A1000001- |
1 |
2 |
13501005 |
12 32 242 |
-MODULE, ELECTRONIC, STEERING COLUMN (EXCEPT THEFT DETERRENT SYSTEM) (EXC.CRUISE CONTROL) (EXC.STEERING WHEEL RADIO OPERATION) (IDENT HC) |
(C) |
-A1999999 |
1 |
2 |
20964879 |
12 32 449 |
(C) B1000001- |
1 |
2 |
20909328 |
12 32 439 |
(C) A1089651- |
A1999999 |
1 |
2 |
(20964877) |
(12 32 447) |
-MODULE, ELECTRONIC, STEERING COLUMN (FOR CRUISE CONTROL) (FOR STEERING WHEEL RADIO OPERATION) (NLS.- NO REPLACEMENT PART) |
(C) B1000001- |
1 |
3 |
25849366 |
1 99 143 |
(C) A1000001- |
1 |
4 |
25881206 |
51 99 687 |
(C) |
-A1999999 |
1 |
4 |
20817715 |
1 99 332 |
(C) B1000001- |
C1999999 |
1 |
4 |
22902363 |
1 99 415 |
(C) D1000001- |
1 |
N |
4 |
25947775 |
51 99 688 |
(C) |
-A1999999 |
1 |
4 |
20817721 |
1 99 335 |
(C) B1000001- |
C1999999 |
1 |
4 |
22899138 |
1 99 414 |
(C) D1000001- |
1 |
4 |
20817722 |
1 99 361 |
(C) B1000001- |
C1999999 |
1 |
4 |
22926401 |
1 99 416 |
(C) D1000001- |
1 |
N |
5 |
25881204 |
12 35 924 |
(C) A1000001- |
1 |
5 |
25881204 |
12 35 924 |
(C) A1000001- |
1 |
6 |
25881205 |
12 35 925 |
(C) |
-A1999999 |
1 |
6 |
25881205 |
12 35 925 |
(C) B1000001- |
1 |
6 |
22807513 |
12 35 093 |
(C) B1000001- |
1 |
8 |
(25799293) |
(9 14 395) |
(C) A1000001- |
1 |
9 |
(13502301) |
(12 32 304) |
(C) A1000001- |
1 |
10 |
(11610440) |
(12 35 922) |
(C) A1000001- |
1 |
11 |
11569833 |
12 35 042 |
(C) A1000001- |
4 |
12 |
11569832 |
12 35 041 |
(C) A1000001- |
2 |
13 |
11569832 |
12 35 041 |
(C) A1000001- |
2 |
14 |
11570587 |
12 34 100 |
(C) A1000001- |
2 |
15 |
13326419 |
12 38 728 |
(C) A1000001- |
1 |
16 |
11570769 |
12 38 837 |
-SCREW, COVER |
(C) A1000001- |
3 |
