Results 1 to 3 of 3
Thread: CIM Problem?
    Member stonedagain's Avatar
    Dec 2013
    Durham
    8
    Vectra C
    CIM Problem?
    Bought a vectra a couple of weeks ago. Whilst turning the steering wheel, the power assistance is on/off, making the steering feel notchy. When I first bought the car, the steering warning lamp was on, this was caused by the plug for the steering angle sensor on the steering rack not being connected. I re-connected the plug, cleared the fault codes & the warning lamp is now off, but the steering is still the same. There are no fault codes present for the steering or the CIM, but when I read the measuring blocks for the CIM the steering angle sensor shows 0 degrees all the time. Would this mean a faulty CIM or will the steering angle sensor need re-calibrating? Also, is there a steering angle sensor in the CIM itself, or is the one on the steering rack the only one?
      Member iulian1971's Avatar
      Oct 2013
      România
      6
      Astra Mk5 1.3 CDTI
      Hi.
      First of all check the alternator voltage. It must be between 14-14.4V idle speed.
      Steering angle sensor is in the CIM and it should change value when steering. Try to recalibrate it.
      Dec 2013
      Durham
      8
      Vectra C
      Thanks for replying.
      Alternator voltage is fine (the alternator has just been rebuilt). The steering angle sensor is definitely in the rack on my car (no esp). Thre is a short harness which plugs into the rack at one end, the other end plugs into the steering pump. I just can't understand why the CIM measuring blocks show the steering angle sensor but not in the measuring blocks for the pump. My next step is to try re-calibrating the sensor, but for that I need the PIN code. I can't order the car pass for my car until I receive the registration document from DVLA.
  1. Advice and help Please - cim module
    By Gadgetman in forum Zafira
    Last Post: 3rd December 2019, 08:37 PM
  2. Astra H CIM decode hellp either to read or PCB swap
    By Richard Kerman in forum Decoding
    Last Post: 14th October 2019, 11:52 AM
  3. Astra H Cim Read Flash Type
    By Donwoody1981 in forum Astra
    Last Post: 12th August 2019, 06:43 AM
  4. CIM Astra H - decoding
    By Grzegorz__1976 in forum Decoding
    Last Post: 18th March 2019, 09:53 PM
  5. I have a problem
    By HAJI in forum Mechanical
    Last Post: 3rd August 2012, 09:44 PM
