Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Member sarah1331's Avatar
    Dec 2013
    Rotherham
    442
    Vectra c
    Tech 2 and boost
    Hi am sorry for pestering you but I have done everything can boost be altered with tech 2
    I did head gasket and now it boosts at 2500-3000 rpm it used to boost around 1800 rpm
    I replaced intake manifold
    Swirl flap actuator
    Egr stuff a few month ago all was perfect I just did head gasket last week as precaution
    I checked selinoid
    Vac pump
    And replaced vac lines
    Vectra c 1.9 cdti z19dth
    Thank you
      I'm not aware of any setting in Tech2 for boost, it's not anything I've ever looked for.
      Engines aren't my expertise so I can't offer any more suggestions myself.
      2500-3000rpm is fully normal for oem engine if you want to get boost on lower rpm you need a remap and its not a tech2 job
      Dec 2013
      Rotherham
      442
      Vectra c
      Smile
      It was around 2200 for full boost and I could feel turbo at 1800 now I don't feel a thing until 2700 then it takes off like a rocket
      have anyone worked on ecu replaced it, flashed or updated?
      if you compare head gaskets were they same thickness?
      have you any tool available to check boost pressure and trouble codes if yes check it make log and post it
      Dec 2013
      Rotherham
      442
      Vectra c
      Deffo correct head gasket I did it myself am a plant fitter by trade
      Nobody touched ecu at all I have opcom no codes at all even after 100 mile I'll see if I can check boost preasure if I can find it in opcom
      Thank you for your replies
      Dec 2013
      Rotherham
      442
      Vectra c
      Having problems with my injector fuel lines leaking as soon as I replace them I'll update
      Member iulian1971's Avatar
      Oct 2013
      România
      6
      Astra Mk5 1.3 CDTI
      Hi.
      After you repair your injectors, have a look at the diesel particle filter and check the boost pressure valve.
      Dec 2013
      Rotherham
      442
      Vectra c
      Tech 2 and boost
      Boost pressure command 104kpa
      Boost pressure 98kpa
      Boost pressure 1.58v
      Than test
      Well if I see correctly 1st image is at idle and 2nd at around 1400rpm is that correct?
      Have you done this - EGR cleaned, check boost pressure sensor next to egr can be dirty, and a maf
      Is yours fitted with dpf?
      Did a check on mates Vectra at 1488rpm egr should be at around 35-45%
      Boost pressure 106kpa
      boost pressure 1.70V
      sure every car is different but readings should be close
  1. My boost bus progress
    By sycovxr in forum Zafira
    Last Post: 14th December 2014, 06:39 PM
  2. boost control solenoid
    By Bennybizzz in forum Mechanical
    Last Post: 7th April 2014, 08:42 PM
  3. Cdti turbo boost gauge
    Last Post: 30th March 2014, 11:16 PM
  4. Is it lacking boost ??
    By wharton in forum Mechanical
    Last Post: 24th January 2014, 09:04 PM
https:www.diagnostics.org.ukshowthread.php2250-Tech-2-and-boost
