Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Member Clarkey's Avatar
    Apr 2012
    Middlesbrough
    16
    Mk 5 1.9 150 cdti , courts filter , crd 2, fully decatted,
    Hi dom they are saying they think it's a now a REC fault ( peps module ) as they have split it and there is dark tracking on board ...
    Any ideas how to get ignition ????
    • #12
      Member Mark I's Avatar
      Nov 2012
      Brackley, Northants
      86
      Astra H sportive van 1.7cdti
      When I fitted peps, I couldn't turn the ignition on but there is a way with tech 2 by going into the peps unit entering the security code then it would allow me to use the start button to turn it on and program the van. This is assuming that the units are ok.
      Does anything work on the car, interior lights etc?
      I'd go back to basics and check to see if there is power at each unit and that the earths are good.
    • #13
      Apr 2012
      Middlesbrough
      16
      Yeah mate car locks unlocks lights work ... Audio don't ... Interior light does if I remember rightly
      Wht menus can you remember did you use to get into the peps security code mate
    • #14
      to get ignition remove button (needs centre console to be removed) put jumper wire from pin 5 to pin 2
      if you dont want to do this test it with multimeter !!button itself!!
      pin 5 to 2 (ignition) when pressed should bring up continious
      pin 5 to 3 (start) there is resistor fitted so check for resistance
    • #15
      Apr 2012
      Middlesbrough
      16
      Quote Originally Posted by domtorredo View Post
      Dom VX have just phoned and have tried to fit a new REC but can not program as still no ignition they say they have checked button and all is ok there
    • #16
      Nov 2012
      Brackley, Northants
      86
      I've just been out and tried this on the van with no keys any where near it,
      Diagnostics>
      year> 2007
      Vehicle> astra
      Body>
      Peps> "confirm ignition on" press confirm but the button wont work yet.
      Programming>
      Program ecu> If it says ecu already programmed then go to.
      Program Keys>
      Security code> It will ask you to turn the ignition on, now try the button. Mine switched on at this point.
      come out of the program keys screen if they are still programmed and you can work around the whole car.
      If tech 2 cant find the peps unit, its probably u/s but check that it has power to it.
  1. ignition comes on but van won't start
    By lfcmassive in forum Electrical
    Last Post: 29th August 2016, 12:09 PM
  2. Insignia EML on second key turn normal ?
    By willbro in forum Insignia
    Last Post: 22nd July 2016, 01:02 AM
  3. How to remove black tab for access to wiring
    By lfcmassive in forum Astra
    Last Post: 10th November 2015, 08:14 AM
can you remove a keyless ignition button
