Results 1 to 8 of 8
    Member Clarkey's Avatar
    Apr 2012
    Middlesbrough
    16
    Mk 5 1.9 150 cdti , courts filter , crd 2, fully decatted,
    Astra H 2007 Vxr keyless entry -not starting at all fault codes present
    Hi hope somebody may be able to help / shed some light on this for me
    All started on Wednesday morning .. Goes to car as normal unlocks car with fob .. Gets in clutch down presses start button nothing - no dial swoosh no noises nothing .. Can still lock and unlock car
    3 months ago I replaced the car battery to a Bosch S5 ,5 year warranty jobbie ... So takes battery back has it checked out told battery is good but I wanted it changing anyway ( piece of mind )
    Got home fitted new battery and still nothing
    After doing a bit of reading on internet I have come across the CIM recall information .. So a call to VX customer care team and the outcome is my car was not done
    So today I have had me car on tech 2 and it brought the following codes up
    B2910 ESCL PRESENT ( not sure if said blocked now )
    B1011 OPEN / START ERROR INFO STORED ON CIM -C003
    Could not do anything as to do a reprogram I was told need to have ignition on or so am told ... Is this correct or anyway around this with keyless entry .. anybody else ever had this problem
      There have been 2 main issues with the CIM on the Astra
      • Clip fitted to resolve issues with the horn and steering controls (This is the recall vx refer to)
      • Reprogramming due to immobiliser not picking up key correctly (DTCs 1614 and 1616), which does not apply to keyless cars.
      So I don't think either of these is specific to your problem.
      B1011
      The control unit recognises the malfunction of the circuit via an internal evaluation logic. Concerned Terminals PEPS:21 - CIM:18
      This leads to a defective Steering column lock actuator, PEPS control unit or CIM if the wiring checks out
      B2910
      ESCL (Electromechanical Steering Column Lock)
      It may be your steering lock is jammed or broken, try moving the steering wheel about as you press the start button. On Keyed cars you sometimes can't turn the key due to the position of the steering wheel and have to adjust before it will remove the steering lock.
      Apr 2012
      Middlesbrough
      16
      Steering lock actuator - will ask about this
      Is there anyway to get the igniton on to reprogramme the CIM
      What would you do / could you sort this ???
      Cheers
      Member stencils's Avatar
      Jan 2015
      walsall
      11
      Zafira B 1.8
      Clarkey did you ever sort this as I have the exact same intermittent problem.
      Apr 2012
      Middlesbrough
      16
      Quote Originally Posted by stencils View Post
      Electromechanical steering lock
      Not the cheapest part to replace
      Jan 2015
      walsall
      11
      Zafira B 1.8
      oh right so it was as pecky suspected. How much and who did yours? My steering lock is still working tho was yours?
      Apr 2012
      Middlesbrough
      16
      Vauxhall did it mate ... My steering lock would not release and car would not start .. As was keyless
      Jan 2015
      walsall
      11
      Zafira B 1.8
      Right ok mines slightly different steering lock comes off and dash lights up but no cranking. Thanks for your quick replies tho.
  1. Keyless Entry - Non starter
    By wharton in forum Electrical
    Last Post: 31st May 2014, 02:44 PM
  2. Keyless entry issues
    Last Post: 4th October 2013, 09:22 PM
https:www.diagnostics.org.ukshowthread.php2195-Astra-H-2007-Vxr-keyless-entry-not-starting-at-all-fault-codes-present
astra vxr keyless entry wont start
astra keyless entry problemsOpel DTC B3123-04astra keyless start problemsastra h peps no ignitionvxr astra open and startastra vxr keyless entry problemsastra vxr key fob not starting carb1011 opelvauxhall astra keyless entry problemsvauxhall astra wont start immobiliservauxhall astra vxr keyless entry https:diagnostics.org.ukshowthread.php2195-Astra-H-2007-Vxr-keyless-entry-not-starting-at-all-fault-codes-presentastra vxr keyless entryvauxhall keyless entry problemspeps system astravauxall astra vxr problem startingOpel Astra H pick lockastra h key battery can not startvauxhall astra keyless entry immobilizer stuck on astra vxr problemsastra h vxr wont start key fobhow to program vxr keyastra h keyless entry not working
