Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    Member zdravko.primorac's Avatar
    Nov 2014
    Mostar, BiH
    57
    Astra H
    Sorry for waking an old thread.
    My car has wires already but no sensors.
    So I fitted new coolant tank (with float) and the sensor in it.
    Earlier I installed sensor with rubber sealant in washer fluid tank.
    I have an Chinese Opcom.
    So with it I will not be able to activate Check Control?
    Only with Tech 2 it's possible?
    Poslano sa mog LG-H420 koristeći Tapatalk
    • #12
      VIP+ Gav's Avatar
      Nov 2013
      Bristol
      285
      Zafira Tourer & Corsa D
      I have the most update opcom and it does activate it, there are two sections that the check control is in.
      I have also fitted the same sensors to my astra H and all working correct.
      A good way to test to see if its working is to take a bulb out!
      Note, only BID, GID and CID displays with board control will work with check control.
      14 Zafira Tourer Techline FULLY LOADED
      VAUXCOM UPA USB AUTODATA TOLERANCE AVAILABLE IN BRISTOL AND SOUTHWEST
    • #13
      Nov 2014
      Mostar, BiH
      57
      Astra H
      OK, thank you for info.
      I have a GID with BC activated and working.
      Don't want to make something wrong so I will visit my best man (wedding) in Opel service to make it sure working and activate it with Tech 2 or VDI.
  1. check control astra
    By VXRTIMMY in forum Astra
    Last Post: 9th November 2012, 05:07 PM
op com check control
check control opcom
astra h check control opcom
astra check control
opcom check control
op com activate check control
opel astra h opcom check control
activar check control con op com
opcom astra h activate
opcom activation 11
astra h enable check control opcom
cum activez cu opcom check control
activar check control opcom
opcom check control astra h
Astra h check control pecky
opel astra h opcom light check control
check control astra h activare cu opcom
astra h activate check opcom
check control enabling opcom
astra h opcom activations
astra h programming check control
astra h rear wiper opcom
astra h opcom wiper
astra check control opcom
