    Member Evripidis's Avatar
    Jun 2015
    Weymouth
    2
    n/a
    [Astra mk4] - Instrument Cluster and ATWS eeproms
    Hi,
    I recently got into this mania of decoding the inner workings of the eeproms found on the astra mk4 and quite likely others. I am sure this has been done millions of times with various software I just want to see how stuff is actually written on the eeproms.
    I have read the contents of the instrument cluster eeprom instrument eeprom_226385.bin using opcom and verified that my PIN is 7446 by byte values "161d" (I know my PIN). If someone can show me how mileage is written the great ! I know that it should be written either encoded somehow or in BCD format/similar.
    Now I am trying to figure out what the PIN is on a spare ATWS unit that I have which I have read the contents of the 93LC56B lcb56b_bin.bin using my pickit. I can see that there are 2 keys programmed in and some patterns but not a clue about where the PIN is. I can start trying out all the suspect bytes, get locked out, retry until I find the right one
    If someone can help out just for the fun of it it would be nice. I can have a spare ATWS if need be in the future.
    Evros
      I must be going blind.. Can see byte values 161d in there.. (now i can, was looking at the atws eprom!)
      I know about the ATWS in the vectra B but it is a different size / layout to the mk4 astra...
      The Ident and the part number are the same between them in the ATWS thats all I can see at the mo..
      Normally you would see the keys on the IMMO and not the ATWS?
      Jun 2015
      Weymouth
      2
      n/a
      Hi and thank you for replying. What do you mean by "between them" ? The unit I read the EEPROM fromm is a spare one I have. I already have ATWS installed and I got the second unit in a joblot off ebay to try out reading the EEPROM since I'd always wondered how this works exactly.
      So in effect the PIN is only stored as 2 byte values in the EEPROM ? In a brute force manner; excluding the recognisable bytes (remote key patterns, we know there is enough space for 5 of them and part numbers, etc), I could keep trying possible PINs until I get the right one ?
      Evros
op com check control
check control opcom
astra h check control opcom
astra check control
opcom check control
op com activate check control
opel astra h opcom check control
activar check control con op com
opcom astra h activate
opcom activation 11
astra h enable check control opcom
cum activez cu opcom check control
activar check control opcom
opcom check control astra h
Astra h check control pecky
opel astra h opcom light check control
check control astra h activare cu opcom
astra h activate check opcom
check control enabling opcom
astra h opcom activations
astra h programming check control
astra h rear wiper opcom
astra h opcom wiper
astra check control opcom
