That is because opcom has a bug when programming check control. It has only been fixed in full licensed version. I proved this to the developer so they changed the programming.
Only Tech2 can remove invalid items correctly.
With op-com i put from not present to present, after save the configuration , but when I go back to check tells me invalid
Tried to extinguish car off and redo the procedure but nothing always invalid
Pecky i'm sorry I have not understood , Buying the fully licensed version then fix it? thank'you..
Original is here http://www.op-com.hu/Distributors_EN.aspx around 900 euro.
Hello pecky we are able to activate the check control ECU from getting there just now tells me that washer fluid levels and do not know where it says that I do not have the sensor
It doesn't say if you have a sensor or not anywhere. If you have enabled it and it tells you the fluid is low when it is not, then you don't have any sensors
I do not have the sensors. but by doing so I was able to get the check control. not there a way to tell the op-com that I do not have the sensors?
Yes turn off check control in UEC
