I plan to buy a new REC on eBay, because I think it causes some troubles with central lock on my Zafira B.
I wonder if it is possible to program it with op-com?
I have already found in BODY-> REC -> Program -> Immobiliser programming, the functions Program Security code to REC; Reset Security code to REC; Write VIN to REC as you see below
Do you think that's the correct thins I have to do to program the new REC. I wonder if I need to reset the ols REC before install and program the new one?
Thanks for your help.
PS : Zafira B 2006 - Z18XER
OP COM : Firmware 1.39 . Software 100219a
