Well make dumps from radio screen ipc and you will get a pin, hope you wont do it with opcom
A quick question, does the Corsa C share the security code across radio, display and other items like the AstraH?
I haven't looked into it but am considering buying one with a frizzed ECU and programming a replacement in order to drive it home. The main challenge is whether I could manage to discover the security code from the car rather than trailer it back and visit the dealer?
Cheers,
Ian.
Interesting, thanks. Looks like the car was sold today (ECU fault) so I won't be able to fix that one. Do you know when the Corsas changed over to the common code?
I'd be using my device programmer, I have never owned an OpCom - bought Tech2 about 6 years ago and got used to having it around - never failed to be able to do something that it was supposed to be able to do. :-)
Ian.
if remember correctly than from corsa c
How do u get dump files with op com
no chance to get dump files with op com only take to bits de solder eeprom read it with programmer if com port available on your pc than you can build programmer for most chips under £10 if not confident with things mentioned previously and with soldering smd components don't even attempt to do it leave it to experienced persons
you should be able to recover code with opcom from corsa
body
instrument
eeprom info
tech two doesn't show this info
Hi where and what is the eeprom from IPC corsa C please
I found one -Philips 82C250 maybe this?
thanks
no idea mate...
bit of research, people are talking about nec processor?
780828
