1st what I would advice you remove radio and try removing and refitting face panel
Recently I come up with the issue, firstly the issue was the GID screen, it stopped working, needed some resoldering in order to get it back to display all the info. Seems everything ok, because before none of the buttons worked (including the temperature control buttons). Now all buttons seems to work, except the navi button where it suppose to spit out the navi cd or take, the issue is that pushing that button nothing happens no cd is spit out. Did anyone come across something similar? My first thought that navi module does not get power supply from main GID screen but maybe I'm wrong.
Can you explain me what you needed resoldering in Gid screen?I have similar problem.My GID sudenly stopped working I tried to resolder connector but did not help.Any ideas?
Already did that, removed front panel, removed cd with maps from navi bay. Still that button doesnt work, I can't even now put back that navi cd back to navi bay, because the mechanism just does not take it back like on audio bay.
As for resoldering, I resoldered all contacts on GID which came from above, maybe few of them had bad contact.
