Results 1 to 9 of 9
Thread: AFL help!!
    Member Astra SRI-TURBO's Avatar
    Nov 2010
    Erith, Kent
    2
    AFL help!!
    Hi all im new to the site and in need of some advice/help. I have a Astra H with AFL fitted but ive got the fault code flashing up on the dash. When i start the car with the lights on they do the ritual of going left and right then up and down. Once they finsh that the nearside light slowly moves down then the fault light starts flashing up on the dash. I dont think they are moving now aswell when i turn around a corner. So frustrating have a car with a toy that DOESNT work. Spoke to Vauxhall and it seems like they dont really no what they are talking about. Any ideas or help would be much appreciated.
    Many thanks Ben
      Hi Ben,
      It can only be diagnosed by putting a diagnostic tool onto the car and seeing what fault codes are present.
      It is also possible to test the lights functionallity and reset the module under the light if need be. Unfortunately a diagnostic tool is the next step.
      It is either a dealer visit, or I can give you details of a guy in Basildon, which is the closest of anyone I know to kent.
      Nov 2010
      Erith, Kent
      2
      Im am booked in for a recall on the horn tomorrow afternoon so ill see if i can get them to plug it in to see what the fault codes are on it.
      Do you know the dealer can test the light functionallity and reset the module??
      If so, i will get them to do it for me tomorrow and see where i get with that.
      Thanks Ben
      Yes the dealer can do everything needed to diagnose the issue.
      They can connect tech2 to the AFL control module, from there they can read the fault codes, do actuator tests and reset the modules.
      The fault codes should tell them what the issue is, resetting the modules may not resolve the issue.
      Member sinke's Avatar
      May 2012
      slovenia ,ljubljana
      1
      astra mk5 1,7
      helo
      i have astra h 2009 and i can't present xenon mode on tech 2(this is what is tell my diller).
      i have oem non afl xenon head lamp, oem ballast, oem ignitior
      is possible to do something because now lap won't stay on or when you start the car light is like strobo in disco
      Member vasilik's Avatar
      May 2013
      Athens
      18
      Astra H 1.6
      Hi pecky! Do you need a secure code of previous car to reset the two AFL modules (a module under each light)? If not, can you describe the reset procedure using the tech2 ?
      We try to program the AFL lights and while the connections are correct, the lights don't respond.
      Thank you!
      Quote Originally Posted by vasilik View Post
      Thank you!
      Hi, No you do not need a code and you don't really need a guide as under the programming menu for the AFL controller is a reset light module function.
      When you say they don't respond do you mean they don't turn on or they don't move?
      I don't think resetting the light modules is your problem
      May 2013
      Athens
      18
      Astra H 1.6
      Thank you pecky for your answer! The lights didn't move but the problem solved! One connection of cables was error so tommorow we will do the programming!
      Regards!
      They need to be programmed in every part of the car they are mentioned on both the canbus and variant configuration before they will move.
  1. AFL connectors
    By James Dennis in forum AFL Headlights
    Last Post: 5th April 2019, 09:40 PM
service afl lamp opel insignia
https:www.diagnostics.org.ukshowthread.php170-AFL-help!!
insignia service afl lamp
vauxhall afl problem
vauxhall insignia afl fault
opel insignia afl problem
opel insignia service afl lamp
afl lamp insignia
insignia afl problems
what does service afl lamp mean
service afl lamp astra
vauxhall insignia service afl lamp
service afl lamp insignia
afl service light
vauxhall insignia headlight problems
afl insignia problems
afl light on vauxhall insignia
vectra afl fault
service afl lamp opel astraafl lights problemsafl erro astraastra h afl probleminsignia headlight problemshttp:www.diagnostics.org.ukhelpshowthread.php170-AFL-help!!afl control unit
