The code for that dump is 5585.
Don't think I have any other dumps from the vectra, when I save them I don't normally note if they are petrol or diesel
Thank you very much,
Also if you can help me with code for this one (other IPC also from Vectra C)?
ipcstef.zip
Can I put this one back on the clocks afther i replace the eeprom?
That code is 3832
Not sure what you mean about putting it back on?
code 3832
well as long as they are same fuel then they should be fine and ipc looks similar 2 types with 2 small screens and 1 screen
pecky was faster
and don't forget mileage oh you got kmh in this dump is 145 792
The eeprom erased after I read it, I don't know what happened, this I had saved it and if I replace the eeprom on the clocks can i put this dump back?
Thank you,
Cristi
now I really cant understand you, so you desoldered eeprom, tried to read it, but erased it? So this dump is from different car or same?
This dump is from the same IPC (car).
Yes, I tried to read the eeprom, read it and after that I couldn't read it anymore like it is blank.
ok than use this dump that will save your time just check all connection on programmer and try again to read it if no success order new eeprom or desolder from same pc stuff etc
Hello,
Could you confirm that the security code for this dump 1231? Astra H VDO clocks.
Thenk you!
Cristiastrahvdo.zip
