Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Member Lao's Avatar
    Mar 2014
    Romania
    12
    Vectra C Estate
    Sorry, I now realized I wasn't very explicit: I was referring to the audio signal ground wire, not to the electrical ground.
    If I'm not about to use the DAB unit at all, I guess I can bypass fitting the switch on the audio ground wire, right?
    • #12
      I understood you, but if the DAB box doesn't receive a signal (because it isn't being broadcast) then there is nothing you can do as the CDC40 shuts off the audio.
      The DAB box reports to the CDC40 that no signal is being received over CANBUS and the CDC40 shuts off the audio input.
      I don't know of a way to get around it, if you don't have DAB broadcasting in your country.
    • #13
      Member Lao's Avatar
      Mar 2014
      Romania
      12
      Vectra C Estate
      I must get my hands on a DAB unit and see what I can do.
      Thank you.
    • #14
      Member teamwesker's Avatar
      Feb 2014
      AYLESBURY
      26
      MERIVA VXR
      hi can I ask how easy the above threads would be to implement as I just brought cdc 40 and want aux to work
    • #15
      Member Lao's Avatar
      Mar 2014
      Romania
      12
      Vectra C Estate
      If I'll do it first, I'll let you know how difficult it is.
    • #16
      Member Ian T's Avatar
      Feb 2013
      Orpington, Kent
      72
      Astra H 1.7 diesel
      A very complicated solution would be to build a DAB box emulator (microcontroller with a CAN interface) so the CDC40 thinks it is connected and working. That opens up all sorts of options in regards displaying something useful on the screen also, but will take some effort.
      Ian.
      Sent from my Nexus 4 using Tapatalk
  1. Is it possible to connect aftermarket DAB+ adapter directly to CDC40 Opera?
    By perdaniel in forum Infotainment - ICE - In Car Entertainment
    Last Post: 23rd October 2019, 10:10 AM
  2. CDC40 and GID help with virgin
    By veteran in forum Decoding
    Last Post: 6th November 2018, 11:39 PM
  3. CDC40 and GID help with virgin
    By veteran in forum Infotainment - ICE - In Car Entertainment
    Last Post: 29th October 2018, 05:15 PM
  4. [FOR SALE] astra h cdc40 uhp4 bluetooth gid and loom
    By jpbroad1970 in forum Parts For Sale
    Last Post: 5th May 2016, 07:02 PM
https:www.diagnostics.org.ukshowthread.php1507-Retrofit-CDC40-GID-DAB-and-UHP4-to-AstraH
vauxhall dab 45 wiring
uhp4
cdc40 dab module
astra h hu connection diagramcdc40 opera gid retro fit vectra cUHP4 Vectra locationvauxhall cdc40 dabhow to install dab module vauxhall insigniafit dab to cdc40cdc40 dab auxvauxhall astra dab moduleadd dab to a cdc40retrofit dab vauxhall insigniainsignia retrofit dabuhp4 cdc40astra h dab wiring diagramuce uhp4reading flash in uhp4http:www.diagnostics.org.ukshopsearch-by-vehicleastra-hbluetooth-uhp4-kit.htmlcdc40 astra hastra h dab retrofitretro fit insignia dab aerialretrofit cdc40fitting cdc40
