Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 31
    Member caza's Avatar
    Mar 2013
    scunthorpe
    10
    astra mk5 estate 1.9 cdti 150
    steering angle sensor.
    hi everybody, i have finished of my dual mass flywheel and clutch today and after driving away from my unit the traction control light has flashed up and also my AFL light sensors light on the dash is flashing. my self canceling indiators also do not work.
    i put the car onto my mates snap on machine and it came up with steering angle sensor calibration although his machine will not sort it? anyone any idea on what could be wrong?
    i know we connected the collum to the rack last and if i remember rightly the steering wheel did move so i dont know if this could be the problem. i hope there is a way to sort this as the lights on my dash are annoying the hell out of me.
    thanks marc
      Yes the steering wheel has turned whilst the knuckle was disconnected. You best hope that you haven't turned the steering wheel too much since as it can rip the ribbon to pieces.
      You need to take the steering wheel off, look at the CIM, in the middle there is a part which can rotate. Rotate it anti-clockwise until it is taught. Then around 2 1/2 turns clockwise should put it in the middle. There is a metal tab at the top that clicks it in place. After 2 1/2 turns approx when it clicks in place, pop the steering wheel on and it should clear the lights. That is if you haven't snapped the ribbon.
      Mar 2013
      scunthorpe
      10
      ahh great. that would show the cheapest way isnt allways the best then. thanks for that info. for disconnecting the airbag is it just battery off for 5-10 mins then undo? i think all my steering wheel controls work. so think that it should be ok? i havent tried the horn but my radio ones work for sure. thanks alot for the answer though as ive just spent hours looking for that.
      Mar 2013
      scunthorpe
      10
      just if it has snapped a ribbon i take it this would be an expensive dealer fix? ouch
      If your steering controls work, the ribbon is still OK, just avoid full lock.
      I never bother disconnecting the battery for any other reason than to stop the horn going off as you wrestle the airbag off.
      p.s a gearbox place did it to mine and ripped the ribbon clean out. Lucky for them I repaired it as a keyless entry CIM is very expensive and rare.
      Quote Originally Posted by caza View Post
      Depends, if it snaps at the connector, it can be re-soldered ONCE if you are lucky, Mine was but it takes it to the limit of slack when at full lock
      Mar 2013
      scunthorpe
      10
      ahh lucky mine isnt a keyless entry model just incase. i will try that tomorrow with removing the steering wheel. thanks alot i will resort back tomorrow with the out come and hopefully it will be a good one.
      Mar 2013
      scunthorpe
      10
      hi i took it anti clockwise and then clockwise it clicks into place every full rotation so on around 2 and a half rotations it seems to be right between a full rotation so no chance of it clocking into postion i did try 2 full rotations with no joy either so im going to try most positions that it clicks into but not turn the wheel would this be ok?
      Mar 2013
      scunthorpe
      10
      just to add i now have my cancelling indicators and also my bluetooth is back up and working. could it just need reseting now? i havent been anywhere in the car maybe the traction control light would go out after i start driving? any ideas? many thanks
      Member Linty's Avatar
      Feb 2013
      Reading
      32
      Astra h cdti1.9 150
      Sorry for changing the topic but anyone knows wats speedos have capability with the ident uq one?
  1. Replies: 7
    Last Post: 22nd November 2020, 01:59 PM
  2. steering angle sensor callibration
    By cheekymonkey in forum Astra
    Last Post: 27th April 2020, 09:49 PM
  3. C0710 Steering Angle sensor
    By Scott McGregor in forum Zafira
    Last Post: 17th February 2016, 04:00 PM
  4. 2128 - Steering angle sensor - Calibration of steering angle sensor not possible
    By pecky in forum Zafira B Technical Service Bulletins
    Last Post: 17th April 2011, 08:48 PM
https:www.diagnostics.org.ukshowthread.php1498-steering-angle-sensorpage2
astra h steering angle sensor calibration
https:diagnostics.org.ukshowthread.php1498-steering-angle-sensor
astra g steering angle sensor
astra vxr steering angle sensor indicators dont cancel
steering angle sensor circuit malfunction astra h
u2143 fault code зафира
astra h indicator not clicking bck off
astra fault code 161300
What sensor can affect the steering angle sensor in the double-clutch gearbox
ecn210306
astra h valeo cim not self cancelling
calibrate steering angle sensoropel astrah
traction light on after changing steering column on astra h
steering angle sensor self cancelling indicator
steering angle sensor astra h
where is astra h steering angle sensor
astra h airbag light traction light indicator eont cancelhttp:www.diagnostics.org.ukhelpshowthread.php1498-steering-angle-sensorastra G steering sensor and traction controlastra 5 indicator not cancellingastra vxr steering angle sensorself canceling indicators on astra 55
