please can some one help me my esp light is on put on opcom comes up with error code c0460-5a steering angle sensor circuit range so were do I look for problem thanks
can be faulty cim module try recalibrate steering angle but not recomend with opcom, can be dusted or crapy ground to photodiodes
thanks for getting back so quick how all this came about was disconnected battery put new drop links and new wishbone arms on connected the battery back up and esp light came on then it would go out but now its perm on thanks
recalibrate steering angle clear dtcs and should be ok you can try with opcom but not sure about results but you can try as if it will work you will save ££ if not go to someone with tech2
I will try this m8 thanks for your help will keep you posted with results
update had my tracking done was out drove car for a bit haho light out happy days cheap fix
