Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    well made quick scetch for you check in image marked as simple as i can
    • #12
      Member ou_jee's Avatar
      Feb 2015
      Finland
      1
      Corsa D 1.3 CDTi DPF 75hp (55kW)
      I hope someone could confirm that I got this right, since my Corsa 1.3 CDTI DPF 75hp (55kW) is missing the wire.
      So, I need to run a wire from:
      * fuse box fuse 11 to
      * pin 3 on clutch switch
      * then from clutch switch pin 4 to
      * x2 connector (stalk 13191079) pin 21
      * and then from x2 connectors other pin to
      * bcm connector 55
      If this is the way to do it and some programming I think it's worth to do it.
    • #13
      My sisters Corsa already had the clutch switch and the stalk connector wiring in place, what was missing on her car was a wire between the column switch module and the BCM, which is quite common to find on the Corsa D
    • #14
      Member Pompeyarnold's Avatar
      Apr 2015
      Portsmouth
      12
      Corsa d 1.3cdti life
      Is there only 2 wires from the clutch switch?
    • #15
      Yep must be 2 haven't seen more
    • #16
      Member 1Dude's Avatar
      Jul 2015
      Market Drayton
      2
      Corsa
      Hello I have a corsa 2008 1.3 cdti I have bought the stalk in and have fitted it i have checked the connector at the back oth the wheel and i am missing a wire so will need to add one, but i am confused regarding the Clutch switch as i have two wires going to it I have unluped this and it does not have a 3rd pin on the switch ! does this mean i will need to buy a new switch with 3 pins ? and connect a new wire ?
    • #17
      Quote Originally Posted by 1Dude View Post
      Clutch switch sounds fine to me.
      Had a corsa the other day which had 2 missing wires from that connector to the BCM, didn't have to touch the clutch switch.
    • #18
      Jul 2015
      Market Drayton
      2
      Corsa
      Ok I will give it a try I will post how i got on, thank you for your reply
  1. Astra mk5 cdti cruise control
    By Maddie2013 in forum Astra
    Last Post: 21st February 2017, 03:33 PM
corsa d cruise control stalk
corsa d cruise control missing wire
corsa d cruise control fitting
1.3 cdti corsa d wiring
corsa d cruise control retrofit
cruise control opel corsa d
fitting cruise control corsa dcorsa d cruise control wirevauxhall corsa d fitting cruise controlcorsa d cruise control switchfit cruise control to corsa dwhere is the mising wire on a corsa cruise controlopel corsa d retrofithttps:diagnostics.org.ukshowthread.php1427-Corsa-D-1-3-cdti-Cruise-Controlfitting cruise control to corsa dinstall cruise control corsa dcruise control not working on corsaopel corsa d cruise controlcorsa d bcm cruise control missing wirecruise control corsa d stalkcan you fit cruise control to a corsa c 1.3 cdticruise controll corsa dcorsa d 1.3 cdti cruise control retrofit can you put cruise control in corsa d that doesnt have it
