Results 1 to 6 of 6
    Member AJ_ZafiraB's Avatar
    Jan 2013
    Stourbridge
    3
    2007 Zafira B
    UHP4 not working and keeping display on? can it be upgraded? will it fix it?
    I have a 2007 Zafira B with factory fit original bluetooth UHP, DAB and CDC40. Recently my battery went flat so I bumped it- its been fine since but the bluetooth hasnt worked since. you cant find it in a search and when you click on the search function nothing happens. Sometimes it freezes and I have to remove the fuse as the display stays on even after I have taken the key out so it will flatten the battery. I've removed the UHP module and the display goes off but the DAB or radio display doesn't work- it just shows the temp. My UHP software version is 01/2006 anyone think upgrading it to the 2010 software might fix it and can Pecky do it?
    any comments appreciated
    AJ
  1. Replies: 13
    Last Post: 10th June 2022, 06:49 PM
  2. vectra c airbag ecu b1000 ecu fault how fix
    By lampinen in forum Vectra
    Last Post: 2nd November 2018, 06:12 PM
  3. choosing upgraded panel filter
    By paulwhite1987 in forum Tuning
    Last Post: 7th September 2013, 04:31 PM
uhp4 not working
