Results 1 to 10 of 40
Hybrid View
    Member Lewis Greco's Avatar
    Jan 2013
    Horsham, West Sussex South Coast
    18
    Astra H 1.6 Twinport
    Hello again,
    Its been a while, work commitments and snow! Lovely, no doubt you were hit with it alot worse up there mind....
    Anyway thought I'd come back for your thoughts on this one!
    So I had a friend (Auto Electrician who owes me a favour) put a crimp on some wire etc, using 0.5 thinwall and connected up to pin 38 of the X1, I crimped a PC header on the other end and connected to the switch.
    On the other leg I connected up 0.5mm thinwall to switched live from Ciggy Illuminating live, also tried live from ciggy lighter & tried live to stereo...
    So connected up and checked the status of clutch switch, on all three lives shows as inactive.
    Started at the switch on all three feeds, multmeter shows 14v OK,
    checked continuity from switch to X1 OK
    checked X1 to UEC pin as advised OK
    Bit stuck with it now, from what I've read this should get me where I want to be. my only thoughts are the cable but i cant see why...
    can anyone help?
    I'm near to writing off the whole thing and consider it an education!
    Cheers
    Lewis
  2. #2
    Jan 2013
    18
    Quote Originally Posted by Lewis Greco View Post
    Hello again,
    can anyone help?
    Cheers
    Lewis
    Anybody with ideas?
  3. #3
    Site Owner pecky's Avatar
    May 2010
    Wolverhampton, United Kingdom
    7,456
    Insignia 2.0 Biturbo 4x4
    For the switched live, the switched live by the ciggy lighter doesn't work for cruise control. It's been a while but I seem to remember the power pulses which knocks off the cruise the second the switch is released.
    I always take the other wire to the thick black wires around X1 connector in the footwell and never not had it work.
    One thing to note is that opcom doesn't always pick up the stalk and clutch switch operation, not even the licenced one does properly so I normally check with Tech2
  4. #4
    Jan 2013
    18
    Quote Originally Posted by pecky View Post
    OK,
    Well I'll try with the wire as suggested, seems abit weird as I cant see anybody else with this issue online ? Do you know which pin this wire connects to?
    If I still have no joy then I think I'll keep an eye out for someone local to Sussex who can check with tech2.
    Cheers
    L
  5. #5
    May 2010
    7,456
    TBH there aren't that many people who retrofit the wire themselves. There are 2 levels of switched live in the Astra H which turn off at different times.
    Ciggy one didn't work with me, nor has it with a couple of people who have contacted me.
    Any black wire will do, it isn't taking a load at all it is just registering 12v at the UEC. You have to splice it as there is no where to add a pin free, if you unpick a factory loom it is spliced in loads of places.
  6. #6
    Jan 2013
    18
    OK,
    I'll try and tap it off one of these black lives and see what the outcome is tomorrow eve, just wanted to wire in loose to the top of the plug to test.
    I'll let you know how I get on !
    L
  7. #7
    Jan 2013
    18
    Evening,
    Well I've been out in the Garage again today, tried all of the black wires at the X1 but still the switch is not showing Active!
    When using a multi-metre to bridge the 2 wires it read 14.23-14.25 volts, same as when switch is connected up.
    So now I'm really at a loss, I've confirmed the connections all the way back to the UEC. Cant understand what else it could be, I know its unlikely but would there be a fuse in the UEC?
    Otherwise I'm thinking it could be the firmware on the ECU, think the freeze date is original release. gonna look for anyone else with same symptoms haven't come across any so far though
    Any other ideas?
    Cheers
    Lou
  8. #8
    Member ilo's Avatar
    Sep 2016
    warrington
    2
    astra h2004
    Is anybody on here that can carry out this work fitting cruise control on1.6 2004 Vauxhall Astra twinport thankS
  1. Astra J cruise control
    By nicos in forum Cruise Control
    Last Post: 6th March 2018, 09:40 PM
  2. Astra h heater control plug wiring
    By lfcmassive in forum Electrical
    Last Post: 16th September 2017, 08:15 AM
  3. Cruise control astra 1.6sxi twinport
    By stuarth in forum Astra
    Last Post: 12th September 2015, 03:38 PM
  4. Cruise control wiring
    By Graham Epton in forum Cruise Control
    Last Post: 13th April 2011, 08:13 PM
astra h cruise control wiring
astra h x1
do vauxhall astra designs have a cruise control wiring loom
Opel astra h passenger kick panel
astra h cruise wiring passenger
astra h 1.6 twinport engine bay modified
astra h engine connector XE3 pinout
https:diagnostics.org.ukshowthread.php1355-Astra-H-05-1-6-TwinPort-Cruise-Control-Wiring
cruise control wiring opel astra h
pedal sensor going to UEC of Astra H
astra h kick panel fuse box
astra h uec
astra h missing cruise control wiring
wiring diagram for vauxhall astra design twinport electric windows
Astra h x1 pin
component location diagrams astra twinport
conector x1 opel astra h
astra h engine fuse box wiring
grey wire fuse box astra h
missing wiring clutch switch astra h
2010 astra parking sensors wiring diagram uk
https:www.diagnostics.org.ukshowthread.php1355-Astra-H-05-1-6-TwinPort-Cruise-Control-Wiringpage3astra h uec pin numbersastra x1is it possible to fit cruise control to a astra twinport
