I'm on the same project as you are :-)
This is what I know..
There is some differences between Astra and Zafira AFL. Zafira do not need control box, there is controller on ballasts (placed on each headlight itself).
So, you need Headlights with ballast unit and lamps, leveling sensor, new connector for left headlight, some wiring, and headlight washing system (if required by the law in your country - not necessary for work of AFL itself). Also mine speedo support AFL, there is warning light for AFL system on it (maybe you'll have to switch speedo due to this - not sure is it important for work)
I had standard lights on my '06 Zafira, swapped with AFL units, changed connector and add some wiring (not all needed). I have stopped my work since, do not have time to finish it. On this point, lights work ok, on initialization (after turning engine on) both lights make a quick full left - right turn. I did not connect leveling sensor yet, nor connect headlights to UEC. As far as I could find, my UEC have support for the AFL, so it would be just matter of connecting wires. And TECH-2 initialization and calibration...
