Sorry VSS a "vehicle speed signal"
Ok I have found the VSS vehicle speed signal and plugged .Now pointer start to move!
But it not gives correct position and speed.Pointer acting like crazy.And every time I start navi menu pointer is always in Norvege near Oslo...And my position is in Belgium near Liege.After some meters is in correct position but not on the right street and pointer move like I drive 200klm/hour.
Somebody has the same issue?
I would try thisJust some info about this radio.
you have to wait for it get gps signal before start a navigation route. If you start a route before gets signal it will get crazy and give wrong gps positions. After that will always give wrong positions. Solution is to drive the car without the gps antenna plugged for about 100m. Then plug the antenna and will start giving the correct position again.
The trick is to wait for it get gps signal. It is much slower than cd70/dvd90 in that
Original Twintop back of CID.I had no problem with Dvd90.
What about if you test oem fakra antenna.
