That's good to know, thanks for the update.
Just some info about this radio.
you have to wait for it get gps signal before start a navigation route. If you start a route before gets signal it will get crazy and give wrong gps positions. After that will always give wrong positions. Solution is to drive the car without the gps antenna plugged for about 100m. Then plug the antenna and will start giving the correct position again.
The trick is to wait for it get gps signal. It is much slower than cd70/dvd90 in that
Installed an oem opc gps antenna and now it get gps signal almost imidiatly. Never had problems again. With this dvd100 fully works on astra h
Hello.Same problem with Dvd100 installed in astra H.
Is a brand new headunit and was first installed on my astra H.
Which cable I must install for speed signal ?
speed signal is normally a blue/red cable from abs
And this cable is already on connector behind radio or I must wire from abs pump?
if your radio was previously something like a cd30 then no it wont be there... but normally its in connector already on front left footwell connector
Hello soulman can you show me some pictures where is this connector on "front left footwell"?
So I plug this cable on my loom on 37pin.
Question:Where can I found the ssv (speed vehicule signal) from ABS ?
