Does your dds button is original or you fitted it?
As if you cant reset it it wont come up on screen
Will try to look tomorrow what AS ident pump is for mybe thats a problem or you missing some coding
Hello,
I'm also trying to finish this retrofit TPMS but I'm struggling to find the right variant code to my ABS pump, can someone please share the ABS hex code from yours ABS pumps. Mainly the ones with TPMS working!
Greetings
Hi.
Wondering if you guys can help me out ?
My car came with DDS and hill start so when I upgraded to a CID I thought it would be great to retrofit the TPMS system.
I have installed the module and sensors and activated everything I could find with Opcom, and done the initialisation set up, both by running the car and by lowering & then setting the pressures, but I only get the dashes on the screen.
Can this retrofit be activated just using Opcom or does it need to be done with Tech2 ?
Cheers..
You need compitable abs pump for it to work ident BN
Ah and tpms sensors in wheels dds uses different approach how to monitor it
As I understand it, if the car has DDS & Hill start from factory, the ABS pump is compatible, if it wasn't they couldn't have been installed?
As I mentioned, I've already installed the TPMS module and the sensors in the wheels.
Give a read to this https://www.diagnostics.org.uk/help/showthread.php?t=82 will give you all info
