Results 1 to 10 of 13
    Member popsi's Avatar
    Nov 2012
    Dublin, Ireland
    5
    Astra MK 5 1.4
    Cruise Control help
    I've fitted the stalk and I've bought a clutch switch. I don't have the wire anywhere for the clutch switch so I'm going from the UEC. The switched live I'm ok with, I'm going to take from the heater controls as I know this works because my headunit is going to it.
    But I don't know where the other pin on the clutch switch is to go to on the uec. I've seen a couple of people saying different things. I've checked under the UEC and from what I've read pin 15 on x2 and pin 38 on x1 are something to do with it, but both of them pins on my uec are blank. I've also read about connecting in to pin 27 on x1, I have a grey wire coming from this pin. So where do I connect in to on the uec?
    And does it matter which pin on clutch switch goes to live and uec?
    EDIT: Ive looked at this diagram and it confused me more, lol sorry
    http://www.diagnostics.org.uk/help/s...H-X1-Connector
      From factory the clutch switch wire goes from the UEC here
      to X1 pin 38
      To Clutch switch.
      It goes through X1 as that is the connector that links the dash loom to the body loom.
      If you have no wire at all, go from UEC to clutch switch and clutch switch to ignition live.
      Nov 2012
      Dublin, Ireland
      5
      Astra MK 5 1.4
      Just to make sure im right. I go from one of the pins on the clutch switch to pin 38 on x1, then the other pin on the clutch switch goes to a switched live?
      No, if you are retrofitting all the wiring ignore x1 connector and run wire straight to UEC.
      Nov 2012
      Dublin, Ireland
      5
      Astra MK 5 1.4
      thats where im lost, where on the uec? possible to get a pic?
      can you not see the pic on my second post?
      Nov 2012
      Dublin, Ireland
      5
      Astra MK 5 1.4
      sorry, yes i can. I realise where I've gone wrong here, confusing xE1 and x1 to be the same thing.
      So from your pic, If I push out the bung labeled clutch switch, say with a paper clip, insert a pin with wire attached and connect to clutch switch. then connect other pin on clutch switch to switched live then all i need is tech2 correct?
      Quote Originally Posted by popsi View Post
      All correct.
      Nov 2012
      Dublin, Ireland
      5
      Astra MK 5 1.4
      thanks a million pecky, your a great guy. you should nearly be charging for this advice lol. I'll be back to buy from the shop on your site anyway.
      I'm always happy to help, not everyone can get to me, so try to help where I can.
      As long as I can fund the server costs by the shop and the people who come to me for works, then I'm happy enough.
  1. Cruise Control
    By Gav in forum Astra
    Last Post: 17th November 2014, 09:51 PM
uec xe1
