Results 1 to 10 of 13
Hybrid View
    Site Owner pecky's Avatar
    May 2010
    Wolverhampton, United Kingdom
    7,456
    Insignia 2.0 Biturbo 4x4
    From factory the clutch switch wire goes from the UEC here
    to X1 pin 38
    To Clutch switch.
    It goes through X1 as that is the connector that links the dash loom to the body loom.
    If you have no wire at all, go from UEC to clutch switch and clutch switch to ignition live.
  2. #2
    Member popsi's Avatar
    Nov 2012
    Dublin, Ireland
    5
    Astra MK 5 1.4
    Just to make sure im right. I go from one of the pins on the clutch switch to pin 38 on x1, then the other pin on the clutch switch goes to a switched live?
  3. #3
    May 2010
    7,456
    No, if you are retrofitting all the wiring ignore x1 connector and run wire straight to UEC.
  4. #4
    Nov 2012
    Dublin, Ireland
    5
    Astra MK 5 1.4
    thats where im lost, where on the uec? possible to get a pic?
  5. #5
    May 2010
    7,456
    can you not see the pic on my second post?
  6. #6
    Nov 2012
    Dublin, Ireland
    5
    Astra MK 5 1.4
    sorry, yes i can. I realise where I've gone wrong here, confusing xE1 and x1 to be the same thing.
    So from your pic, If I push out the bung labeled clutch switch, say with a paper clip, insert a pin with wire attached and connect to clutch switch. then connect other pin on clutch switch to switched live then all i need is tech2 correct?
  7. #7
    May 2010
    7,456
    Quote Originally Posted by popsi View Post
    All correct.
  1. Cruise Control
    By Gav in forum Astra
    Last Post: 17th November 2014, 09:51 PM
uec xe1
