Hello type_rs
your files
GID 93C66_dele.bin code: 2276
GID 93C66_meu.bin code: 5526
Regards Jarek
@Jarek20
Could you help me please?
Vectra B CID ident KH
Astra G CID ident KJ
(93C56?)
Szabolcs
Hello interwarez
Reread EPROMs. In my view incorrectly read. Send photos and ripples CID (serial, GM)
Jarek
EPROM.ZIP
Hello Jarek, :-)
Original Status: NCDR1100 + Zafira A GID (JE) pairing
Siemens NCDR 1100 Radio
(GM11002BLI4951)
Alpha code: UR4
Hardware number: 2402
Software number:3204
code index: 22
code version: 2
Date of manufacture: 3004
GID (Zafira-A)
Siemens 5WK70043
21.06.02-20
24435393
CID: Vectra B
Alpha code: KH
GM No: 24439377
Siemens 5WK
Code index: 14 (X20XEV)
Code version: 2
Date of manufacture: 1401
Best regards :-) :-) :-)
Szabolcs
Hello interwarez
NCDR1100 - no code for eprom (flash crypto code is 29LV160 for navi) + GID JE: code 3869
CID KH: 3869
CID KJ: 0000
red files eprom GID JE your adress 00000000:
BAD
34 32 33 34 33 35 33 39 35 31 39 39 35 32 32 30 4234353951995220
OK
32 34 34 33 35 33 39 33 31 35 39 39 32 35 30 32 2443539315992502
....for end eprom.
Regards Jarek
Could not be read due to an incorrect ID TECH2 with?
I am grateful, thank you!
I still look for you!
Best regards :-)
Szabolcs
Hallo Jarek,
Astra G GID "WE" eprom copied Vectra B CID "KH" display and turn upside down! (reverse image)
The system works but the picture is the other way around!
The EEPROM array which needs to be improved?
What do I need to change that settles a picture?
I'll have much help!
93c56_ori_GID_WE.zip
The set:
Astra G GID <-> Vectra B CID
NCDR1500
TM
CDC
GID changed from CID
GID replace CID
Best regards
Szabolcs
KJ and KH display is facing the same picture!
018: C2 20 F7 00 1F 03 38 C2 --->KJ
018: 42 20 F7 00 19 03 38 C3 --->KH
018: 46 00 F7 00 41 03 38 C3 --->JE
018: C6 20 F7 00 41 03 38 C2 --->WE
020: 08 50 6C 3C 14 8C 50 06 --->KJ
020: 08 50 6C 3C 14 64 32 06 --->KH
020: 08 14 6C 3C 14 7D 16 06 --->JE
020: 08 14 6C 3C 14 FF 64 06 --->WE
red files eprom - ???screen translation??? - 020: 08 (14-->50) 6C 3C 14 FF 64 06
Best regards
InterWareZ
