Nearly forgot about you
so this is a bit where arrow points in your image 13169630
but this is a bit what goes around screen (screen sits in) 13169624
Thank You! This will help a little
Now I have to work out brightness problem... Possibly with another memory dump.
Has anyone got a Meriva 2006+ GID KU version memory dump, please (I found one on this thread but it has problems with brightness)?
Hi,Attachment 1052
gid display 93c66 16bit and 8 bit bin files
please code
9499 , 9949 - is wrong codes
Right code is 9499 but may be you have a entered
more than once wrong code and have wait time active.
Check for wrong codes and wait time with software who you are use.
Kind Regards
How did you try to use code?
if all other units has different code than it wont work put back all your original units and disable theft protection that put new gid in and activate with code 9499
my mistake ..
9499 is correct code ( wait time active ) ..
thanks
i have a problem with another one gid display
9163 is it correct code?
File moved to Dump Archive
REPORT GENERATED BY PECKY'S VAUXHALL DECODER
File Name: gid 93C66 8 bit sandanski.bin
Unit: GID and CID Display
Manufacturer: Siemens VDO
EEPROM Type: 93C66 EEPROM
VIN: W0L0XCF0864105470
Security Code: 5993
Hardware Number: 13156842
Part Number: 13127055
IDENT: KU
Software Freeze Date: UNKNOWN
Code index: 01201
Is this meriva dump? Other member was looking for one with ident KU if its meriva can be useful for him
This is Corsa:
http://ecat24.com/catalog/vindecode/W0L0XCF0864105470
but surely I will try to use this dump
If remember corectly they are same but not sure so try and report
