Hello,
can you help me with proper binary file for Meriva GID (KU Siemens VDO)? I was tinkering my own eeprom programmer and I accidentaly erased whole bank... Now I have a bunch of zeroes instead of dump, which I can post here to you guys...
Have you done your screen?
Hello,
Did you erased it with software pressing erase button or when you read it you get only zerous? Erased eeprom should show ff instead of 00 so try reading ir again and check your programmer could be loose or no contact somwhere
Yeah I know of FF values. But in this case it was programmed with zeroes. I tried to reprogram chip with any values to check if it's broken. Luckily chip is ok. I will try with dump I found on this page.
Will post any progress soon.
By the way. I want to buy back casing for GID display for Meriva 2006+
Just back what goes on screen assembly or surround what goes around screen? Ok if it was programmed with 00 than its different story, im not at home at the moment but will check when get home what i got from meriva i have seen few on forum so you can try
problem is solved with many difficulties.
big thanks
Ok thats good, used different dump?
Yes just the back (with one screw under small cap). Black colour to be precise I'm looking for it, as the man from whom I've bought display hadn't got it.
p.s. I'm very sorry for my eng. I'm using it only for reading documentation, so I confuse grammar a lot.
Well cant imagine that bit in moment but will look at bits what i got maybe will find something, my english isnt much better then yours im not originaly from uk so no worries fully understud what you mean
