Use 2008 disc insert and turn off turn on and wait when it spits disc out remove don't allow it to retake it
If this doesn't work
Copy mcu of same ident and freeze date and flash your mcu
I tried to update my cd70 navi, in a zafira -07, with a dodgy update and it went south!
Since then I've tried to burn softwares eg. 102007 and 042007 in compact discs (not dvd-s) in 10x speed with nero and use them for the rescue mission.
No luck. My cd70 navi behaves like it's bricked! To switch it of I now have to remove the fuse! When I take out the fuse and retry the feature " software upgrade" flashes in the screen for 1 or two sec. then it goes away again. Nothing happens even if I let the cd in for hours switched on. I can't reach through "test mode" the reset bios fature. It wont let me. I've have since then ordered the original 102007 cd from Germany and tryed without luck. I tried taking the fuse out and reinstalling it, whilst the cd was inserted, but it wouldn't help. I tried disconnecting the battery and switchin it on agin, but no luck, even though I'm using the original radio update cd 102007.
I realy need advice about how to go about to rescue my cd70 navi infotainment system, if it's possible.
Maybe I'm not doing it right?? Do I need another (later) software or should I do it in a special other way?
Please help, since you seem to be knowledgable about this problem.
Tips before upgrade:
- Start update after a short trip so the battery has more charge
- Burn on quality brand CD (Verbatim works great) and lowest speed 4x-8x.
- Best to use Nero burner software. Avoid ImgBurn or CDBurnerXp or if use them then double check that image is burned with low speed and CD type=Mode2
- Better not to use laptop CD/DVD writer
- Order original Opel/Vauxhall update disc to avoid any problems as burning additional CDs in case of errors eventually will cost the same.
Update:
1. Insert ignition key/Switch CD70/DVD90 ON
2. Insert update CD. Follow prompts (Update takes about 15 minutes to complete)
3. Remove CD when update is finished
Recovery procedure:
In case update fails for any reason hangs it is possible to recover successfully, try reinserting the update CD and try the update process again.
Q:Cannot eject disc!
A: If disc can't be ejected then hold Eject button and turn on/off ignition. CD then should eject.
Q: How to restart failed update?
A: Remove Infotainment fuse or battery cable. Leave the CD inside. After it powers on it will show "software update" and start again. If it doesn't start then try update while ignition key is in but not turned to ACC. Burn additional CD and try with that or just order and use original update disc.
Q: How to rollback update (in case no progress indicator showed up)?
A: If unit recognizes software update CD but failed to reboot from the disc it has already set the 'flash update' flag and stays in the update mode even if update didn't actually start. In this case the lang cd can be used with a working loader that can restore the flash update flag to 'no' once it recognizes that there is no language loading required.
Q:To burn the image nero 10 burns the image in mode 2 and imgburn uses mode 1.Which mode is the correct?
A:You should burn a Nero (NRG) image with nero in order to preserve the Mode setting
Mode 2 is required for a successful burn
Update
tried switching on and off no luck what I did is split the whole unit and connected the sat nav rom to the cd plug in and pressed eject for cd and whey hey it ejected ,I then built the radio back up and trying putting the radio update disc again , It took disc in very slowly and yet again nothing.
How do I copy the mcu and freeze date and flash mcu???
thanks
Ray
If sarah mean eeprom than with eeprom programmer
If you can eject the cd when it’s connected to the cd plug, that means you have problems with your navi plug on main board (solder) or your front pannel has bad connections (navi eject button won’t work if bad solder on front pannel connector on the main pcb ).
Hi
Funny you should say that as I was taking the sat plug back in I noticed a pin high up not touching the board but what I find this weird is it was all working till I done the radio update???? from the Vauxhall orig cd
What happens if you plug the cd drive on navi connector? Does it eject?
would anyone send me a PM for 10/2007 Firmware CD, please. I want to enable AUX-IN.
Thanks in advance!
Hi
Would anyone be able to point me in the right direction for the 10/2007 upgrade CD?
