Results 1 to 3 of 3
    Member romanster's Avatar
    Aug 2012
    Canada
    10
    Saturn Astra XR 3
    [Astra H] Hazard switch assembly partially stopped working
    Hi all, in need of some help regarding the central hazard switch assembly.
    My H came with a 4 button hazard switch bar.
    I bought a 6 button with heated seat controls to retrofit, but when I connected the switch bar to test it out it would not turn on the hazard lights, lock the doors, etc.
    When I put my original 4 button bar back in, it also stopped working! No hazard lights, and the LEDs behind each button no longer light up. The only thing that works is the lock switch, but the red indicator LED doesn't turn on. From the pinout diagrams here it doesn't look like I could have shorted anything, and the fuses are all intact still. The turn signals work properly from the steering wheel stalk. It just seems like the switch bar isn't actually sending orders anymore. Also confused as to why the LED backlights stopped working too?
    Any ideas or help would be appreciated, I'd like to troubleshoot this before giving it over to the dealers.
    Thanks!
      7,443
      Just changing the switch bar should not cause any issues. Are you certain the connector is locked in fully as it is possible to turn the lever on the first cam and it will close without pushing the connector fully onto the pins.
      Keep the lever in the open position and push it is as far as you can before turning the lever.
      I've seen that happen before.
      Aug 2012
      Canada
      10
      Saturn Astra XR 3
      Yup, that was it! It was locked on the first cam like you said. I made sure to push the connector on all the way, and now all functions are working fine on both switch bars. Thanks for the help!
  1. Replies: 21
    Last Post: 4th April 2016, 11:31 PM
  2. Astra H - Hazard switch unit
    By pecky in forum Astra H wiring diagrams and connector pinouts
    Last Post: 20th February 2011, 12:38 PM
how do you get to the hazard switch on astra h
astra hazard illumination fuse
astra h hazard switch removal
astra h hazard warning switch removal
opel hazard switch test
opel astra harzads button
vauxhall omega hazard switch doesnt illuminate
astra h hazard switchremoval
opel astra hazards not working
opel astra hazards and signal lights dont work
no power to hazard switch vauxhall
my hazard lights and door lights is not working on my opel astra
how to remove hazard button vauxhall astra
opel astra no hazard lights
hazard fuse for astra mk5
06 astra hazard lights not working
hazard light sport button and locking button not working mk 5 astra
changing hazard switch for astra h
how to remove hazard switch in opel astra h
how to change a hazard switch in an open astra h
how can I remove opel astra h hazard switch
hazard lights fuse astra h
astra h hazard wiring
astra h hazard light button live
