Results 1 to 5 of 5
    Member IMPFreely's Avatar
    Jun 2012
    Romford, Essex
    3
    Astra H 1.7 CDTi
    Retrofitting Cruise Control to Astra H 1.7 CDTi
    Hi pecky,
    I hope you can help me. I've fitted the CC stalk and had a garage tech2 the car to activate the cruise control and it didn't work. Being a diesel I know it already has the clutch switch fitted so I'm wondering why it wouldn't work?
    Now I've read about cars having certain wires missing (namely the tutorial written here) - does this apply to my car? I checked behind the clocks and there isn't any wires taped to it.
    Also, the garage run some tests and confirmed they can see the CC 'on' signal being transmitted by the stalk but it wasn't being picked up/process by the ECU - does that mean I need to run this wire described above?
    Thanks for your help!
      You will have no wiring missing at all, there is no reason it will not work.
      Tech2 can check for the clutch switch operation, Opcom can't due to a bug.
      If the clutch, brake and stalk are all working then it will work.
      Are you sure it is not working and not just the light not being on the dash. If your foot is any where near resting on the clutch, it will not work as the switch is very sensitive.
      Jun 2012
      Romford, Essex
      3
      Astra H 1.7 CDTi
      Thanks for clearing that up before I took the car apart to find I already had the wiring...
      It's definitely not working! Been very careful with the pedals etc like you said.
      Think I need to get the tech2 stuff checked again, bizarre that it didn't work first time.
      When connected to Tech2, get them to check for the brake pedal, clutch and stalk buttons working correctly. If the clutch or brake say active whilst not being pressed then the problem is there.
      Also clear all fault codes.
      Jun 2012
      Romford, Essex
      3
      Astra H 1.7 CDTi
      Plugged tech2 in and it turns out the clutch switch wasn't working properly! When the pedal was released it didn't push on the switch enough to activate it...so I've glued a small rubber stopper on top of it and bingo, cruise control works a charm. Thanks for your help!
  1. Astra mk5 cdti cruise control
    By Maddie2013 in forum Astra
    Last Post: 21st February 2017, 03:33 PM
  2. Replies: 4
    Last Post: 19th January 2016, 12:37 AM
astra h 1.7cdti mods
astra cruise control fitting
astra h cruise control coding
does my astra h have cruise control
retrofit cruise control on a astra mk4 17 tdci
astra g 1.7 cdti cruise control
retrofit cruise control astra cdti
astra 1.7 cdti fitting cruise controlvauxhall astra h 1.7 cdti sxi clutch switchdoes mk4 astra cruise controlastra g 1.7 cdti fitting cruise control site:diagnostics.org.uk astra sxi cruise controlastra g 1.7 cdti cruise control retrofitfitting cruise control to vauxhall astrado astra h 1.7 cdti club have a clutch switchcruise control astra 2012astra h clutch switch wiringastra h sxi cruise controlhttps:www.diagnostics.org.ukshowthread.php1064-Retrofitting-Cruise-Control-to-Astra-H-1-7-CDTiis it possible to add cruise control to a vauxhall Astra diesel mk4astra g cruise controlastra g cdti cruise lightretrofitting cruise control astra h cdtiastra g brake light switch with cruise controlopel astra h cruse control retrofit
