Battery consumption problem
Hello, I have a battery consumption problem and it seems that it comes from the cid screen of my Astra H, when I turn off the ignition a beep is heard that never goes away... on the other hand, in other cids, that beep occurs shortly after if it is removed. .. I have to be removing the ECU fuse so that it doesn't consume the battery...
What could it be?
thank you
