    Member TomF's Avatar
    Jun 2020
    Northwest
    6
    Astra Mk5 VXR
    Issue with Astra H Factory Fitted AFL Lights
    Has anyone come across fault code B1455-00 Right dynamic curve light position circuit malfunction ?
    I keep getting this code intermitantly and not sure how to diagnose it, Where is the position sensor located ? Is it on the actual light assembly or in the module underneath the headlight ?
    The Lights do the correct start up sequence as they should..
    Any help appreciated, Thanks
      VIP+ kadett90's Avatar
      May 2014
      Finland
      230
      Opel Astra H
      Short to voltage/ground or interruption in circuit to control unit terminal 2, 5, 20
      Above condition must be fulfilled for at least 3 s .
      Concerned Terminals:
      AFL: 2, 5, 20
      Here is something to start.
      Ignition OFF
      Remove electrical component from socket:
      A3_E119R Power Light Module, Right
      Ignition ON
      Measure voltage between the following terminals:
      Socket Terminal 2
      Ground
      less than 0.3 V
      Jun 2020
      Northwest
      6
      Astra Mk5 VXR
      Quote Originally Posted by kadett90 View Post
      AFL: 2, 5, 20
      Ignition OFF
      Ignition ON
      Socket Terminal 2
      Ground
      less than 0.3 V
      Thats great info, will give that a try, thankyou !
  1. Sat Nav + AFL Lights For Astra J
    By Slugz in forum Astra
    Last Post: 4th May 2014, 06:40 PM
  2. Trouble with factory fitted Bluetooth
    By wharton in forum Electrical
    Last Post: 15th September 2013, 11:22 PM
https:www.diagnostics.org.ukshowthread.php10001-Issue-with-Astra-H-Factory-Fitted-AFL-Lightsgoto=newpost
astra h afl off
